30 Amp Lines & Whole House Surge Protection
I agree with Terry DeWickt on using 30 amp lines for your Audio and or H/T system. They're not code, but you can generally find an electrician who will work with you, as we did.
The reason 30 amp lines are not code is that U/L (underwriters labs) mandates all regular consumer electronics not draw more than 20 amps, so the code for regular household wiring is 20 amps: The regulators believe if you run a 30 or 40 amp line to a 20 amp product and the product malfunctions, it can catch on fire and burn your home down. This IS a risk, so proceed with using a 30 amp line at your own comfort level.
I would also STRONGLY RECOMMEND installing a whole-house surge protector in front of your breaker box (between the powerline cominging into your home and the breaker box) - It's the cheapest insurance you'll every buy and you pick up the additional benefit of protecting EVERYTHING electric in your home. Many local power companies now offer this service for a monthly fee, but you can generally have an electrician install one for about $150 or less and you should plan on replacing the giant MOV it uses every few years as a general safety precaution.
We did this when we moved into our present home in 1995: We also had two separate 30 amp lines with NEMA outlet terminals installed in our den for our Audio and Video systems before we moved in. The electrician thought we were nuts, but he did the work.
Where we live, we have had some terrible lightning storms here in the mountains, and have never had a problem other than occasional power outages - Never any damage when the power comes back on. Call me anal, but we also use high quality internal surge strips as well.
