upgrading to mac
Discussion in 'McIntosh Audio' started by oneputt, Jun 19, 2017.
  1. oneputt
    oneputt New Member
    26
    Thinking about going to Mac gear. Right now I'm using a Pioneer SA-9500ii or a Lafayette LR-9090 receiver with Celestial-Ditton 442 or JBL L100's. I switch back and forth between all the components. Right now in my area there is a MAC 2205 amp with a C 28 pre-amp for sale at what seems to be a reasonable price. Also at a lower end is a MAC 1700 receiver at a fair price. I know there is quite a difference in power between the two but also a big difference in price. Ive also read if i want a receiver the 4100 is the one to get. Any thoughts or opinions?
  2. Mamrak1
    Mamrak1 AK Subscriber Subscriber
    769
    Pennsylvania
    I would try to find out if any of the Mac gear has been maintenanced/upgraded. Those separates should an be an upgrade over a Lafayette receiver.
    asilker likes this.
  3. oneputt
    oneputt New Member
    26
    Both the amp and the receiver have been serviced. The Lafayette is a surprisingly good sounding receiver. Couldn't pass it up as it was only a couple hundred and in mint condition. Needed some thing for the garage
  4. Mamrak1
    769
    Pennsylvania
    I've said it in other posts. A receiver's power supply can't compete with a full blown power amplifier.
  5. nj pheonix
    8,335
    New Jersey
    When i was a kid , a friend's father had a 5555 and at the time I thought it sounded pretty nice. I had a 1700 and its a nice piece. I restored a 1900 for my brother and was pretty impressed. Separates are a step up. It's a deep rabbit hole grasshopper. Be careful! Oh and enjoy!
    62caddy likes this.
  6. louisjames
    louisjames The "real" Louis James Subscriber
    1,774
    If they're all serviced and the price makes sense then starting out with a 2505 and C28 sounds like a nice intro to the club. But as nj pheonix said - - it is indeed a rabbit hole and you can quickly get caught up in the goodness and to some, the loonies that is McIntosh. Not to mention the $$$ that can quickly leave your wallet. :)
    62caddy likes this.
  7. sberger
    sberger Hard Core Geezer Subscriber
    "Serviced" could mean a proper going through, changing out caps/resistors where needed to bring up to spec, or it could mean hitting it with a few sprays of DeOxit. File under knowing exactly what you're buying. They're all older pieces, so at the very least they should all be looked at by someone(maybe that's you?) who knows what they're doing.
    Other then that, it comes down to preference and budget, especially the latter. They're all good pieces, and in good working order will all sound great.
    62caddy likes this.
  8. TSmith8605
    TSmith8605 Senile Member Subscriber
    704
    Sunnyvale, CA
    What does "serviced" mean in this case. What, exactly, was done, by whom and when?
  9. kevzep
    MC2205 would be a great amp to buy to move on from what you have, but I would go for a newer pre-amp, the C28 requires a lot of work to function reliably, and since you had the SA9500, you'd definitely want something like a C33 or 34 to eclipse that....
  10. damacman
    6,793
    Gilbert, AZ
    If you want an upgrade from what you have at present, the C28/MC2205 would be it. Be forewarned, the C28 is a very maintenance heavy unit, well documented here.
  11. 62caddy
    8,152
    NEPA
    Truthfully, a [fully & properly restored] MAC4100 will get you 95% the way there of the combination the McIntosh C28/MC2205 combo.
    Personally I'd lean towards a C 3X model preamplifier which are the next generation up from the C28, as well as being generally more reliable as damacman has pointed out.
  12. louisjames
    1,774
    While the Lafayette does not, it appears your Pioneer has a pre out so you could potentially get the 2505, which is a very sweet amp, use the preamp section of your 9500 and then look around for a 3X series McIntosh preamp as 62caddy suggested.
  13. oneputt
    oneputt New Member
    26
    So your saying I could use my 9500 for a preamp until i find a better fit for the 2205. I really don't know if i need that much power, 200wpc is a lot. The speakers i use don't need that much power, thats why i was thinking about a 4100.
  14. louisjames
    1,774
    My speakers don't need the 300 watts per channel of the MC7300 I have but it sure does make em sing and the high wattage seems to lend a certain girth or "weight" to the overall sound quality. :) You would want to check and make sure and most probably one of the more tech savvy forumites can chime in. But I've used an integrated with a preamp out as a stop-gap and it worked just fine so no reason your 9500 wouldn't work unless it's a mismatch impedance-wise. Wasn't as nice as my McIntosh pre, but certainly doable and this gives you time until you find the units that best fit your needs. Certainly could not go wrong with a 4100 either. I've always liked those but prefer separates myself.
  15. damacman
    6,793
    Gilbert, AZ
    Yes. Simply connect the PRE OUT of the 9500 to the input of the MC2205.
  16. AlTinkster92
    AlTinkster92 AK Subscriber Subscriber
    3,066
    NC
    Thanks for the heads up on the C28! Was looking at one to fill the empty space my MX114 sat..:)
  17. mark warren
    mark warren Always Learning! Subscriber
    1,323
    southern USA
    I have been thinking about a C28 also its good to know they have probs!
  18. damacman
    6,793
    Gilbert, AZ
    C28's biggest challenges are the non-sealed pots that require continual cleaning and the numerous ground drains that c_dk has discussed at length.
  19. 62caddy
    8,152
    NEPA
    ...and the volume control....;)
    The C29 or C3X series would be a major step in the right direction for reliability if nothing else, plus a superior tracking volume control that is supposed to track within 1 dB across its range.
    Audio Classics now says they're rebuilding original C28 volume controls. So far I haven't learned whether they've been able to improve upon the originals...time will tell.
    AlTinkster92 likes this.
  20. c_dk
    c_dk Addicted Member
    5,492
    West Michigan
    The C28 is a great sounding preamp with a excellent phono section, but they are 50 years old. You have to go into one with your eyes wide open. The have been enough posts highlighting the things that need to be done to get them back up to proper performance. It is easy to see them once the top cover comes off. Buyer beware, do not purchase one unless it has been restored competently or you allow $400-500 for a tech to do it after your purchase. Really the same thought should go into any purchase of any unit that could be considered as "State Of the Art" 40 to 50 years ago.
