Using a multimeter on a circuit board
Discussion in 'Solid State' started by CavScout, Nov 6, 2018.
  1. CavScout
    CavScout Well-Known Member
    602
    Medicine Hat
    I am fairly new to working on electronics but I am learning.
    One challenge that I have had is testing the parts (caps, resistors, transistors etc).
    The top of the board is almost impossible to take readings from and the back of the board is an incredibly hard to follow map (especially when you can't position the receiver in a position for easy board access).
    Online schematics are faded and hard to read.
    Is there a trick I am missing here ?
  2. dbxdx5
    dbxdx5 AK Subscriber Subscriber
    2,710
    Other people will have their own methods, but when I can't make out what's what on the solder side of the board, I try to stand the unit on its side and shine a pen light from the component side. That usually helps me get close enough to figure out what I'm looking at.
    Lavane likes this.
  3. elnaldo
    elnaldo Addicted Member
    7,438
    Buenos Aires GMT-3
    +1. Also, try to locate some hole, heat-sink, screw, whatever you can see from both sides of the board, and use it as a reference, then mark with a marker on the solder side the components you need to measure. Checking continuity ("beep") with the meter from one side of the board to the solder side can help to verify you are at the right component.
    Anyway, I don't see any trick you are missing. If schematic is not readable, board not accessible, not too much you can do. I'd remove the board if needed. Find the less invasive method. Sometimes you spend a lot of time to do some work without disassembling , and it takes longer than disassembling, work faster, and assemble again.
    Hyperion, merlynski and dlucy like this.
  4. CavScout
    602
    Medicine Hat
    That is what I am thinking.
    I had a guy on this forum tell me once " you should never ever ever remove a board from the unit because ALL work can be done without doing so"
    I am thinking of clipping the wires, remove the board.......test.......fix.......resolder the clipped wires.......test unit
  5. elnaldo
    7,438
    Buenos Aires GMT-3
    I think somebody saying or writing that sentence would be thinking or referring to a particular unit. Or he was kidding. Definitely not all work can be done without disassembling. And sometimes the hardest part of the work is just disassembling-assembling, perhaps to replace a $0.05 capacitor.
    merlynski, I LIKE MUSIC and dlucy like this.
  6. Bob
    Bob AK Subscriber Subscriber
    2,447
    West coast
    couple of points
    1. take pictures. or rely on your memory (we had a thread here regarding just two very different diodes
    and it took 20+ threads, wide advice variation, educated guesses, and it worked)
    2. if you cut wires, put little paper tags on both ends. tape the group of wires if they all go to a spot
    on the PCB AND label the pcb similarly. better to do all this and simply desolder.
    3. mark all electrolytic caps by polarity on the PCB (ignore stenciling if different) -
    confirm with schematic. use something like red marker.
    if you really want a good guide, take a picture of the top using a high quality camera not a dumbphone.
    then take a picture of the PCB solder side. reverse the top side, match scale to bottom side
    and print both out. this tells what the top side looks like when viewing the bottom. I leave the
    small details to the execution.
    find a good schematic and match to PCB components, and parts list, - all must agree.
    merlynski likes this.
  7. teal'c
    teal'c Moomber Subscriber
    17,084
    Michigan, N of Detroit
    Yup, experience. Practice makes less pain in the ass.
  8. CavScout
    602
    Medicine Hat
    Here is what I am struggling with .
    A monster receiver that I have to mount on its side to work on and getting on both sides of the board is difficult.
    But cutting all those wires looks intimidating to reattach ( a sh*tload of soldering)
  9. elnaldo
    7,438
    Buenos Aires GMT-3
    Seems you have a very good access to the solder side. I think you can remove almost every component from that board with a little patience.
    What do you need to do on that board?
    I wouldn't cut all those wires.
  10. Lavane
    7,735
    northern cal.
    Using a light can help a lot. Unless your working on the newer boards with double layered traces. It can be like trying to figure out a complicated freeway interchange from the air. :D
  11. merlynski
    merlynski Curmudgeon Electronicist Subscriber
    662
    High Plains, Eastern Colorado
  12. satellite65
    satellite65 AK Subscriber Subscriber
    678
    Chicago - NW suburbs
    If I have a service manual with board layouts, I print one regular and one mirror image.
    elnaldo and merlynski like this.
  13. Scott75s1974
    Scott75s1974 Active Member
    222
    Ohio
    Yes, I'd see about getting one of those LED work lights that are stacked around hardware store checkouts--the kind with a strip of LEDs. Could you slide one behind the board? Easier than holding a flashlight in your third and fourth hands while desoldering.
    That doesn't look like too complex a board. I often reach around the board and pinch the part and its lead on the bottom to locate. Then I mark the pads of the one part I'm working on with a black marker. Desolder, replace, repeat. Occasionally I desolder the wrong lead. Not big deal.
  14. Binkman
    6,787
    Chapel Hill, NC
    I also use the flash lite and get a ball park on transistors. They are easy to identify. then you get reference points. We posting to a newbie will agree that you just need to keep studying and identifying. You can work both ways.. output transistors back to power supply transformer then trace back to outputs.. red, black markers wash off with iso pro. alcohol. Make notes on printed crappy sm and take pics suggested. You can make your own wire identification by writing on masking tape to numbered board point.
    we're here to help!
  15. avionic
    45,588
    Fort Dodge, Iowa
    Buy new manuals.
  16. CavScout
    602
    Medicine Hat
    Yeah...off Ebay...for like $30-$50 ...when they are available
  17. avionic
    45,588
    Fort Dodge, Iowa
    What are you working on?
  18. avionic
    45,588
    Fort Dodge, Iowa
    Don't cut the wires. Unsolder the wire wrap pins.
  19. avionic
    45,588
    Fort Dodge, Iowa
    Wire wrapping is a better connection than solder.
  20. Binkman
    6,787
    Chapel Hill, NC
    Above noted Q of model?.. but whats wrong with it? was it working?
