Using Mac ma6200 or 6900 as a pre
Discussion in 'McIntosh Audio' started by Chimbot, Feb 11, 2019 at 11:27 PM.
  1. Chimbot
    Chimbot Member
    56
    Curious here... let’s say if I came up on a MA275. Instead of having to buy a dedicated pre-amp, would a ma6200 or ma6900 be a suitable pre-amp?
    I’ve heard that the 6200 was equal to the C26(!?!) preamps? Not sure about the 6900 even though it’s more beastly in power.
    Curious as to what light any Mac Vets out there can shine.
    Cheers!
  2. seacliffe301
    seacliffe301 Well-Known Member
    569
    Michigan
    Absolutely, an MA6200 would make a fine choice as a preamp (think C32, almost). Far more features as well as improved SQ over a C26 (especially the phono section).
    Simply remove the rear panel preamp to amp jumpers, and patch direct to your power amp from the preamp out jack.
    Chimbot likes this.
  3. 62caddy
    9,905
    NEPA
    The C502 would be the closest kin to the preamp section of the MA6200.
    Chimbot, Archguy and seacliffe301 like this.
  4. Chimbot
    Chimbot Member
    56
    Hey, thank you for this info! Ok- someone I talked to also said this in regards to my ma6900- that I could just use the power amp portion of the 6900 and buy a tube preamp. He said I might get a bit more tasty feel all around.
  5. Yamaki
    4,348
    Hillsboro, Oregon
    Yes, you can use the 6900 as a pre-amp/amplifier or get a tube pre and run that pre-amp's signal to the 6900 and let act as a power amp for your speakers.
  6. frodaddi
    frodaddi Active Member
    108
    Atlanta GA
    Or use a Y connector between the pre/amp connections and hook up the internal amp and an external amp, then you can choose either/or/both. I did this with a MAC1900 for a while, makes for a versatile setup.
  7. seacliffe301
    569
    Michigan
    I would not advocate using a Y connector on a source path as it drastically changes impedance. An audio DA would be a better way to accomplish this.
