Scott Becker
New Member
I have read several threads about Zilch and others liking the BMS 4550 drivers to replace the 802 on the 811b horn, but have not be able to find specific changes to his Z-19 crossover that may be required. Is there enough adjustment with the way his L-pads are set-up to run the higher sensitivity 4550 without additional padding? Haven't ordered them yet, but would want to order any other crossover components at the same time.
Some of those treads showed members also preferring the SEOS-15 horn to the 811b. SInce loading of the driver will be quite different, did they use an entirely different crossover than the Z-19? All the comment seem to be about sound vs. changes in crossovers that I can see.
Thanks for any links I've missed or insight.
