merrylander
AK Member
Since I never seen to set prices at where people want, I would appreciate opinions on this 8080DB. It arrived with no case, seller said it blew fuses. One output, a 2SC1116, was missing but the tie down screws were dangling in place, probably causing a short. Tested the three outputs and all were good, replaced the missing one. No fuses blew but it stayed in protect mode. Replaced most of the fusistors on the driver board, now it came out of protect mode, but no FM. Found a transistor in the 12.5 volt regulators that some genius had installed backward. Rebuilt the board just to be safe. Aligned, adjusted and now she is fine
Next step was a case, after much measuring, gluing, veneering and four coats of poly this is what it looks like. Some minor scratching on the face, mostly around the headphone jack - guess your aim gets bad after the sixth beer.
So there you have it.
Rob
PS: I changed my mind and stained the Cherry red.
Rob
