vincei
aka MasterControlMedia
May as well post my tube system.
The audio chain is:
Music server playing WAV files into an Auzentech sound card w/OPA627 opamps. Custom cables then feed my home built 300B SET using fixed bias and Mundorf silver oil coupling caps. The amp is an all film cap design with minimal parts count. From there, the power is fed to Magnepan MG-10QR, yes Maggies with a SET! For the low end I use an Athena Sub, which should be swapped for something better eventually. Sound is rich and clean, with lots of detail and resolution, it's loud enough for my needs as it's a small room. You can view higher res pics from the link in my sig below...
The audio chain is:
