Hi folks,
I'm new to this stuff. I recently picked up this turntable at a barn sale. I absolutely love the aesthetics of this thing, although I'll be building a new box/surround for it as that part is pretty damn crude.
So, I can't figure out where the buzz is coming from. There's no ground(unless the cartridge is internally grounded?). I replaced the tonearm wires and the buzz just got worse. I then found that one of the RCA plugs was loose/broken internally so I swapped out the RCA cables for another set and the buzz persisted and changed. Should I swap out the entire assembly all the way to the pre-amp? Cartridge is a Pickering XV-15.
Any help would be much appreciated. Again, I'm a novice so judge lightly.
0-6 by ,
0-4 by ,
The black wire was connected before so that wasn't the problem.
0-2 by ,
And my sloppy repair job...
0-3 by ,
0-6 by ,
0-4 by ,
0-2 by ,
0-3 by ,
