The Lafayette T-4000 is on the bench and she is a little dirty, I hook her up to my SX-850 and variac. The shure cartridge is in great shape, almost new. I had to adjust the speeds 1st, the 33 1/3 speed adjuster is at it's full limit to play a lp. I see it is starting to go down as I used the table.
It sounds very nice for now, smooth operation, easy belt install, I don't know the size, I put a 24.5 flat belt on it for now.
Anyone know how the speed controls work on this table? If I clean the pots that are used for the speeds, will that work. Seems to be getting better as we speak.
The motors are rubber mounted so if you grab the shaft that is sticking through from the underside and move it with your hand it will wobble. However if your watching it spin and its wobbling then it might be bent or out of balance.
Hi,
When I turn it by hand it shows to be bent slightly.(it plays ok though) Are new motors available for this type of TT, or is there something I can substitute it with.:scratch2:
