Vintage Mc275 One Channel Weaker
Discussion in 'McIntosh Audio' started by drillher, Jul 8, 2018.
  1. drillher
    drillher AK Subscriber Subscriber
    1,681
    Upstate,N.Y.
    I have a vintage Mc275 that had a total rebuild aside from some of the resistors that were not out of spec.The right channel is weaker.When I reversed the preamp.inputs,the same rt.channel was weaker.Also,the amp.now sounds dull like there is a blanket over the speakers.I had a replacement tubes for all but the 12AT7's and the change made no difference.I ordered two NOS 12AT7's and should have them next week.Hopefully it is one of them.
    Dave
  2. TSmith8605
    TSmith8605 Senile Member Subscriber
    837
    Sunnyvale, CA
    Did you also reverse the speakers to see if the weaker side stayed with the amplifier or the speaker. I assume tweeters are OK.
  3. twiiii
    twiiii Addicted Member
    6,704
    west Texas
    Seeing How you are close to Audio Classics, I would go pay them a visit. I should be so lucky. Now you know why I own SS. Not that they can't have troubles, too.
  4. drillher
    1,681
    Upstate,N.Y.
    I will try reversing the speaker wires.
  5. drillher
    1,681
    Upstate,N.Y.
    I sprayed all of the pots and the input switch,which didn't help much The following day when I reversed the speaker wires,it solved the problem some how.Both speakers are equal now.I'm not sure if cleaning the pots took 24 hrs.to kick in or if there some how was a bad connection on the rt.speaker terminal.Could a wire underneath the speaker terminal,inside of the amp,have a cold solder joint?
    Grbluen likes this.
  6. clinic-audio
    2,312
    France
    Cold solder joint ? No !
    the problem with very old units is that somebody sometime use a wrong screw to tight the speaker connection and make the output from output transformer shorted to ground
    this is the first thing to double ckeck when you buy an old unit
    check each screw to see if they are identical length
  7. drillher
    1,681
    Upstate,N.Y.
    Thanks for the tip on the screws.Right now everything is working.
  8. clinic-audio
    2,312
    France
