Mine says 42.5v. You should put 4 10 or12v light bulbs in series the they should work.I have one, since 70's. Not a technician. Second time lights quit, I found schematic, but no lamp specs. Volume lamps are four in series in 45 volt circuit. I replaced two bad with 5 volt lamps. Did not have any luck repairing mine. Possibly a power supply problem. None of my lamps work. All other funcions fine. I gave up. Good luck.
BTW, welcome to AK.
I was quoting from memory. May have been 12 v lamps. May revisit again, to see if I can get them. working.Mine says 42.5v. You should put 4 10 or12v light bulbs in series the they should work.
The 12v lamps work.I was quoting from memory. May have been 12 v lamps. May revisit again, to see if I can get them. working.
Instead bulbs I used LED with minor intervention in electronics wich drives bulbs. There is two current sources: one for volume indicator and one for other indicators. You just need to change two resistors in each cs in order to define different size of current (about 10 mA). 330 ohm resistor instead 110 ohm between B+ and emitter of PNP transistors in cs. Now connect LEDs in series (4 white high briight for volume and 9 yellow and green for other indicaticators). Tricky part is connect diodes in exact position-anode from one to catode of another. Of course you need a service manual.
My first post on AK
