Volt+ D vs NuForce STA200
Discussion in 'New Gear - Performance' started by gkarelitsky, Oct 31, 2018.
  1. gkarelitsky
    gkarelitsky AK Subscriber Subscriber
    1,411
    Ridgewood, NJ
    Looking for a small form factor amp to drive older B&W speakers of 90 db SPL. Preamp is a NuForce HAP-100. Not looking to rock out the house but would like good dynamics for jazz and classical, primarily.
    I have read good things about both amps here on AK. The Volt + D seems like a good value but would it be outclassed by the NuForce? Any benefit staying with the NuForce brand?
    HiFiJeff likes this.
  2. bigx5murf
    bigx5murf AK Subscriber Subscriber
    1,471
    Las Vegas
  3. 45rpmspinner
    45rpmspinner AK Subscriber Subscriber
    As far as I know, there are no tests of the Volt+D to back up that assumption.
    Even Allo offers nothing of the sort.
  4. bigx5murf
    1,471
    Las Vegas
    But there are plenty of resources that have measured the various Chinese implementations of the tpa3116. The general conclusions are, the tpa3116 only measures poorly when gain is set too high from the factory.
  5. musichal
    11,903
    Norman OK
    Try the NuForce. Send it back if you don't like it. Chances are good you will keep it, I believe. That HAP-100 is a pretty good little preamp. I had one. Only sold it because no one used it in the guest bedroom - I just had one too many systems.
    WobblySam and invaderzim like this.
  6. gkarelitsky
    1,411
    Ridgewood, NJ
    Appreciate the feedback. No concerns about driving the somewhat inefficient B&Ws?
  7. bigx5murf
    1,471
    Las Vegas
    ClassD amps actually drive low impedance speakers better, long as power supply and cooling is adequate. Remember they were originally designed for automobile use to drive 2ohm speakers.
  8. gkarelitsky
    1,411
    Ridgewood, NJ
    I decided to go with the Volt + D and it arrived yesterday. Initial reactions are quite good. Ample power to drive the B&Ws at the lower gain setting with nice dynamics. Can’t say that I understand why but it seems to provide a noticeable soundstage. Looking forward to seeing if it improves after a break-in period. Very happy with the performance at price.
  9. HiFiJeff
    HiFiJeff Super Member
    1,370
    Colorado Springs
    How did it take me 15 days to see this thread?!?!?! I am SOOOOOOOOO close to pulling the trigger on the STA-200. I have a thread over in solid state on the STA-200. I also love my Volt+. But am considering the +D.
  10. gkarelitsky
    1,411
    Ridgewood, NJ
    if you go ahead with it be sure to come back here with your impression and comparison.
  11. HiFiJeff
    1,370
    Colorado Springs
    Looking forward hearing more impressions. I have the normal Volt+ and am thinking about going to the +D.
    Without a doubt. I am leaning more towards the VOLT+D though. A lot less expensive.
  12. HiFiJeff
    1,370
    Colorado Springs
    Well it’s been over a month since you have had your Volt+D. How do you feel about it now?
  13. HiFiJeff
    1,370
    Colorado Springs
    I said I was leaning towards the Volt+D but since I already own the Volt+, I am going to get something else. Most likely the STA200 if it is still available in a month when I am planning to make a purchase.
  14. gkarelitsky
    1,411
    Ridgewood, NJ
    I am enjoying it. I have to look at other speakers, though. It is currently driving a pair of B&W DM 602s which may not be efficient enough at 90 dB SPL.
  15. Dadbeh
    Dadbeh Schrodinger's meerkat Subscriber
    594
    is it quiet? if there is nothing playing do you hear a hiss or humm from your speakers up close? this is a concern for me because my main speakers are 98db efficient.
  16. gkarelitsky
    1,411
    Ridgewood, NJ
    I find it to be quiet, but again, with inefficient speakers, so ymmv. No hiss or hum at all with my cdp or CCA. There is sometimes a bit of noise with phono but that may be a separate issue. My TT is not well isolated at the moment.
    Dadbeh likes this.
  17. gkarelitsky
    1,411
    Ridgewood, NJ
    Figured out my problem with phono. I tried 4 TTs in that same location and they all produced lots of noise. I was beginning to think that I was done with vinyl.
    My son came over and suggested I move the CCA away from all the cables and voila.
  18. HiFiJeff
    1,370
    Colorado Springs
  19. HiFiJeff
    1,370
    Colorado Springs
    Guess I will get to answer this question real soon! I am giving the NuForce a spin and see what happens.
    Real curious to see how a $69 amp stacks up to a $1399 now $499 amp. True David and Goliath battle.
  20. HiFiJeff
    1,370
    Colorado Springs
    Got here early this morning.
    fredgarvin likes this.
