JRSBat
Well-Known Member
I had made most of the regular tweaks to my Scout that had been discussed here before. I don't think this one has been mentioned.
A couple weeks ago I received a nice gift from a generous EBay customer - a box of very expensive EAR damping material scraps. I figured I would try out the material on my Scout - just to see what happened.
I removed everything down to the plinth and feet. Then I removed the metal plate screwed to the bottom of the Scout. There is some adhesive between the plate and the wooden plinth, but the plate can be pried off without damaging the plinth if you are careful. After scraping off the adhesive I applied two layers of the damping material to the metal plate.
I reassembled everything and played a familiar album - major difference. Everything was deeper, richer and still kept the music detail I wanted. I changed the phono preamp setting to 47k for my MC cart and everything became even sharper.
You can't see the difference unless the table is in very bright light - like the camera flash. I used the EAR materials but you probably can get similar results with other high quality damping materials out on the market. I am very happy with the tweak - but your results may vary.
4 First Layer of EAR Dampening Sheets Attached to Scout's Metal Plate.jpg50.6 KB · Views: 76
