WhiskeyRebel
Registered thread killer
I've finally completed the center channel speaker I made for my living room. Now I just need to hang it up on the wall and put a grill on it.
I haven't weighed it but it contains two 8" woofers, two pieces of 18"x33" 3/4"MDF, about 8' of 1x6 and 9' of 1x8", plus a couple tubes of Liquid Nails. It takes a bit of doing to lift it up.
The back of the speaker is 3/4" MDF. Think it would stay up if I screw brackets straight into the back or are the screws likely to pull out?
I suppose I could attach brackets using toggle anchors, and put some caulk or more Liquid Nails to seal the hole drilled to pass the anchor through. Overkill? Just screw it?
Had I attached brackets to the back before attaching the back to the cabinet, I could have used machine screws with fender washers under the nuts. I may not be able to get at the inside of the back through the driver holes, because I soldered the wires onto the speakers and stapled the wires tight to the inside of the cabinet to avoid any rattles. I'd have left a "service loop" in the wire and / or wired the woofers in with disconnect terminals if I had anticipated the need to get in through the driver holes. Live and learn.
