Want to clean the front controlls on my AU-7900 amp.
Discussion in 'Exclusively Sansui' started by dpg3, Jun 16, 2017.
  1. dpg3
    dpg3 Well-Known Member
    566
    I searched the Sansui forum here and Youtube for a detailed information on how to do this but didn't find any.
    I am a totally newbie to cleaning the amp, so I just need some detailed info how to clean the front controls of my AU 7900, so I don't damage anything.
    I have Deoxit and I know you spray it into the openings on the controls and turn them about a dozen times, once you take the top off the amp, just want to make sure I'm spraying it in the right places.
    I read that I might have to take the faceplate off to get at the various toggle switches is that true?
  2. dpg3
    566
    Disconnected the amp and took the top off but not quite sure where to spray the Deoxit?
  3. Hyperion
    42,007
    Hertfordshire, UK
    BLAH BLAH and dpg3 like this.
  4. dpg3
    566
    I read the first thread and will checkout the second one. Just wish there was more info on the AU-7900 in particular.
  5. dpg3
    566
    I've read both of these threads and the problem is even though the go into detail about cleaning an amp they don't specify how to clean on an AU-7900. I've taken the cover off the AU-7900 and I don't see any covers on the pots with access holes to spray the DeoxIT. I know I have to take the faceplate off to spray the switches can I access the other pots when I do that?
  6. petehall347
    petehall347 the brandy coffee man
    24,495
    uk.. the middle bit
    could you post some pictures please ? it should maybe help .
    dpg3 likes this.
  7. bolero
    bolero Well-Known Member
    617
    Ontario
    dpg3 likes this.
  8. petehall347
    24,495
    uk.. the middle bit
    if the bottom cover comes off go in that way .if not some taking apart is needed . front panel off . remove nuts from correct parts . pull out pcb with pots attached .
    sorry to be generalising here but never worked one .. most amps etc are pretty similar .
    dpg3 likes this.
  9. dpg3
    566
    Yes I can, I'm going to work on it Tuesday when I have a day off. I'm also waiting for some DeoxIT to come in that I just ordered online.
  10. dpg3
    566
  11. dpg3
    566
    Yes I can do most of that just have to know where on the pots and switches do I spray the DeoxIT?
  12. Willy6
    Willy6 AK Subscriber Subscriber
    1,208
    Pacific northwest
    In the hole..
  13. bolero
    617
    Ontario
  14. dpg3
    566
    Yes, just need to know exactly where to spray.
  15. dpg3
    566
    Here are some pictures not of my amp but they are exactly the same as my amp, I had the top and bottom off. Just need to know where to spray? I don't see the holes in the pots, that other people speak of, on amps where you spray into?
  16. petehall347
    24,495
    uk.. the middle bit
    i cant see the pots on those pictures .
    dpg3 likes this.
  17. dpg3
    566
    OK thanks!!
