I have an Infinity IL 120s sub.
I used RABOS to set it up.
I do not leave it always "on" (standby), I switch it off and on when I am going to use the system.*
Listening last night, in the dark, to a CD I really like for it's (IMO) good quality and wide range of frequencies, I just feel it's a good "test" CD. While listening I decided to check the sub low pass freq. setting.
Since it was dark, I used a flashlight to check the settings on the back of the sub....imagine my surprise when I see the RABOS is switched "off" and the phase is "0". During setup I preferred phase at "180" and RABOS "on".
Most likely at some time when reaching behind the sub to turn it on or off I accidentally hit those switches and switched them from the up position to the down position.
WELL, that made a difference changing them back to where they were set during the original setup.
Tighter more stable bass.
Simple thing, easy to overlook.
*Having read and seen online more than a few cases of Infinity sub amp board failures makes me think having it powered on only when listening MIGHT help prolong its life?
Or is leaving it powered up and in standby mode ok to do?
That would at least help ensure I don't accidentally change the switch positions in the future.
