I had picked up some W60D speakers at an antique shop probably about 2 yrs ago by now. Bought them untested. Didn't pay too much for them so it was a risk I was willing to take. Got them home, hooked them up, and ....blah. They were lacking in the upper end. Fiddled with the pots and no difference. Nothing coming out of the tweeters. Oh well, stuck them in the corner.
Fast forward to today. I figured I'd pull the bad tweeters to figure out dimensions for some new replacements. Hey, since they are already bad, let's see if we can fix them. What do I have to lose?
From the looks of it, these did not "burn out". I seems that the leads to the coil just corroded.
Ok, fine. I'll solder on some new leads and be good to go. Well, I couldn't get the solder to stick to the leads coming from the coil?? I then realized the coil was aluminum wire.
So I looped the aluminum around the copper and soldered the copper. The soldered copper loop would hold the aluminum. That seemed to do the trick.
Then it happens. I was forming the leads to fit under the dome and one of the leads broke off at the coil. That was a good waste of at least an hour. Now if I could just remove the coil from the dome, I'd rewrap it in some copper. Unfortunately, the glue used is not going to give in without damaging the dome.
I had some paper cone tweeters laying around and kinda fitted them in. Sound good until I figure out what I'm going to do for replacements.
