Thumpy
Well-Known Member
I picked up a Luxman M-12 power amp a while back and I haven't had time to try it until today. I thought to myself, "Hmm, power amp. I need a pre and a source. I'll use my Sansui 9090 receiver, pull the pre-main jumpers and connect RCA-ended cables from the Sansui pre-out to the Luxman main-in." Got the speakers hooked up to the Luxman. OK, Sansui on, set to "FM", volume all the way down, speaker outs "off". FM stereo light on, tuning centered, signal strength good. OK, fire up the Luxman. A couple of seconds, then the speaker relay clicks. So far, so good. I inch up the volume and voilà, glorious music! But when I turn the balance ring on the Sansui to the left, both channels fade out. Hmmm, I didn't expect that. I move it back to the center and both channels sound normal. I try again, with the same result. Geez, did I hook up the speakers incorrectly? A quick glance show they are correct. Maybe the 9090 needs DeOxit, but I just did it a few weeks ago and it should last longer than that. Well, it turns out that turning the outer balance ring was also turning the inner knob - the volume knob! Just when I was starting to take myself seriously...
