Before you buy bulbs, measure the DC voltage across the Stereo indicator light. Dial across a strong FM Stereo station. The voltmeter should indicate voltage when stereo is being broadcast. If you see voltage but the bulb is not lit, the bulb is bad. If you don't see voltage when tuning across a stereo broadcast, the tuner needs to be adjusted.
As far as the dial pointer, if it flickers, you need to clean the function switch and check for bad connections.
- Pete
