What are your favorite Cantilever materials & Diamond shapes?
Discussion in 'Turntables' started by OldADC, Feb 13, 2018.
  1. OldADC
    OldADC Member
    97
    Nashua, NH
    At ADC, the design philosophy carried forward from Peter Pritchard was low effective mass, high compliance, low VTF. The basics of the design were exactly the same ranging across the whole product line from the $5 cartridge in a blister pack sold through Radio Shack up through the Astrion at $400 (in '82, inflation adj for today $1062). The injection molded plastic bodies and stylus holders were of different colors, the output pins identical. The magnetic circuits internally were physically the same parts but the windings of the coils were of different wire sizes and # of turns. So the bodies were substantially the same. If memory serves, there really were only two body configurations. The coil assembly used on the low end of the product line up to and including the QLM36, and the bodies used on all the high line product starting with the XLM. There may have been a slight change around the XLM II Improved, but it wasn't a big deal. Thus, if the stylus holder fits on the can of the body, ADC styli are interchangeable across bodies close to universally.
    Why bring this up? I've seen lots of questions on here where people have an ADC stylus and want to know if it will fit on another model's body. The biggest question is actually based on the mu-metal can of the body. If you look toward the bottom rear of the can on both sides, there is or is not an L-shaped bump on the can body. That bump was added to the ADC basic body design in 1979 by John Kuehn after some extensive testing and validation. The later bodies with the L bump and the styli that fit them, fit much tighter and much more stably. So now the matrix of compatibility is based on bump/no bump and high line/ low line.
    And now for the real reasons. The high line was really differentiated by cantilever and diamond selection. Within the bump/high end quadrant lies the most modern and interesting of the ADC product line. XLMII, XLMII Imp, XLMIII, ZLM, Astrion. And within that crowd you find tapered aluminum tube cantilevers on all but the Astrion which was the first sapphire rod cantilever ever used (after extensive testing of Boron rod, Beryllium rod, and the sapphire rod in engr tests and double blind listening tests). Diamond selection at the time included ellipticals, modified ellipticals, the Shibata cut, and some experimentals where the diamond vendors were trying a few things out, particularly different ratios between the bearing and scanning radii.
    Which cantilever materials and which diamonds do you like and why? I'd love to hear your opinions on these subjects.
  2. lini
    lini just me...
    5,951
    Munich, Bavaria
    I'd vote for diamond-coated, tubular, tapered beryllium with a nude stone with 0.06 x 0.06 mm square shank, "pierced-through mount" - so pretty much what Yamaha offered on their MC1000. However, I'd like the tip to be a tad sharper and maybe also to sport a slightly larger major radius (Yamaha "only" offered a line-contact version with 8 x 40 ┬Ám). Well, at least for best quality, that is.
    Whereas personally I could already live very well with anodised, tubular, tapered alu with a nude stone with reasonably small (max. 0.2 x 0.1 mm, better 0.14 x 0.07 mm), rectangluar shank and sharp, true elliptical tip, also "pierced-through" mount - as sported for example by the ADC RSX or the Audio Technica ATS13, ATN13 and ATN130E/132EP. To my ears the needles in that class already do well enough, that I don't really miss anything - provided the records still are in pretty good condition.
    Greetings from Munich!
    Manfred / lini
    bobins08 and 808_state like this.
  3. vincei
    vincei aka MasterControlMedia
    3,356
    Montreal, Canada
    Hands down Microline stylus, this gives me the lowest tracking distortion. I also use a Boron cantilever and like it very much as well.
    Grbluen likes this.
  4. gusten
    gusten Addicted Member
    5,370
    Stockholm by night
  5. c_dk
    c_dk Addicted Member
    6,400
    West Michigan
    One of the finest, if not the finest cartridge I ever had the chance to setup and listen to was the prototype MCs made by Mr. Imamura (Mark Corporation) for Gordon Gow and McIntosh.
    He let me keep and resell #2,3,and 4 while #1 and 5 went to the factory for their evaluation.
    Opening up #3 of 5 with Gow was like Christmas with a youngster. Extremely small rectangular shank modified elliptical insured a extremely low tip mass. I believe the cantiler was a tapered aluminum tube.
    While exotic materials and technics showed off the technical muscles of the cartridge designers so often the smaller more important details were ignored.
    It was obvious that every attempt was made to minimize tip mass and still keep a scan radius that minimized wear.
    In examining the latest offerings from AT with my Wild scope the amount of excessive diamond shank extending thru the cantilever I have found questionable.
    As usual in most audiophile endeavors the small details being attended to often brings better results than high tech materials.
    malden likes this.
  6. revox-b77
    revox-b77 AK Subscriber Subscriber
    3,081
    Fingerlakes, NY
    I am very happy with the ADC XTIV. It does everything right. Sure would like to try an Astrion some day.
    The lighter stiffer cantilevers add an immediacy to the sound that I like.
  7. Mister Pig
    Mister Pig Pigamus Maximus Subscriber
    10,646
    Olympia Washington
    I see this line of thinking to be similar to what is the best DAC chip for a CD player, or what are the best output or circuit for an amplifier. I personally don't see how any end user can have an informed opinion of what diamond and cantilever contribution s to the final product that is the cartridge. Especially in the realm of moving coils, which is where I concentrate my interest. There are so many factors that effect the outcome as much as the cantilever material and diamond type. Johnathan Carr said in an interview that the dampening materials and techniques in a design made more difference than anything else to the final voicing of a design. I have owned cartridges that I thoroughly enjoyed with all types of cantilever materials, from gemstone to boron to aluminum(straight pipe and tapered), and diamonds from elliptical, shibata , fritz geiger, miroliine, microridge, Replicant 100, and so on and so forth. I prefer to decide if I like the cartridge as a whole or not.
    Perhaps the MM cartridge guys can have a more informed opinion due to their ability to fit multiple diamonds and cantilever assemblies from a cartridge line to the same body. But then there are the parasitic losses from having a friction fit stylus assembly. So there are some downsides also.
    I guess I just can't form a strong opinion on this as I own cartridges with boron, gemstone, and aluminum cantilevers. Diamonds would preferably be some variant of line contact, but I have owned elliptical fitted ones in the past that I thoroughly enjoyed.
    Regards
    Mister Pig
    Tedrick likes this.
  8. illinoisteve
    illinoisteve Super Member
    3,104
    Sicks munce ugo eye coont even spel cantuhleever.
    (Seriously, I'll be reading with interest trying to soak up info from folks who really know this stuff.)
  9. Brian Tambe
    Brian Tambe Active Member
    325
    I just purchased one of Audio Technica's newest cartridges from their new VM line , the VM 740 ML ( micro line stylus ) Aluminum alloy cantilever and housing for less vibration. It's being mounted this Saturday the 17th and I can't wait to hear what this baby is going to sound like. It's replacing a dinosaur ADC Series 1 that has been on my Technics SL-D303 since I purchased it brand new form Pacific Stereo in 1981. My TT is worthy of this quality cartridge because it is in absolute Pristine condition and works perfect in all phases. I'm going to have the spindle lubricated when I have the cartridge mounted at the same time. I'm bringing the entire table so Scott can set the counter weight of the tone arm and set the anti skate to meet the recommended gram settings for this new cartridge. I have a question , since the elliptical stylus is so old and worn down and has probably widened the grooves in my LP'S , should I avoid playing my old albums with this new cartridge and purchase brand new vinyl to protect the styli? I'm worried that the new Micro line stylus is going to have too much room to move around in the record grooves due to the grooves being widened by the old worn and flattened styli. Won't this cause not only damage to the new styli but also sound like GARBAGE? It's going to set me back quite a bit of money to start my LP collection all over again with brand new vinyl at prices ranging from $15 to $25 each. I've been told that the new vinyl LP's being made today sound better than the vinyl from the 60's 70's and 80's , is this true?
  10. c_dk
    6,400
    West Michigan
    The new AT cartridge will ride lower in the record groove, have a longer narrower contact with the groove wall and therefore have a contact surface greater than most old school styli.
    You could pull up some extra crud from the bottom of the record groove so a good deep cleaning of your old records might be in order, depending how well you did this in the past.
    The last VM740 I installed was in a Sumiko FFT-3 arm, make sure your installer sets the VTA correctly and pays close attention to I believe is the Technics Stevenson arm alignment.
  11. Wildcat
    Wildcat Audio Sommelier Subscriber
    5,601
    MI, US
    Cantilever? Lightest possible material.
    Stylus tips? Only a "line contact" type. I got tired of lesser styli tearing up my records.
  12. Brian Tambe
    325
    Thank you very much for the help regarding my question. Do you like the VM740ML?
  13. Brian Tambe
    325
    c_dk , will the new Micro Line styli get damaged from being ran through grooves created by the very old Elliptical styli from my current ADC Series 1? I have ALWAYS kept my records clean by using the disc washer system with a styli brush. I'm a fanatic with all my gear and the records are in great physical condition , I'm just afraid the grooves in the records will damage the new styli on the VM740ML because that old styli , being worn down and possibly widening the record grooves and not allowing the Micro line to track properly and perhaps even move around in the record groove due to the groove being tore up by that old elliptical styli.
  14. Pio1980
    Pio1980 AK Member Subscriber
    27,628
    Eastern Bamastan
    The main problems would be accelerated wear from a dirty record or the stone being flicked off the cantilever by a flaw.
    Otherwise, the worst that can happen from a clean worn record is degraded sound.
  15. c_dk
    6,400
    West Michigan
    These AT questions should probably be in their own thread.....
  16. malden
    malden Addicted Member
    5,268
    That's really what it's all about.
    needlestein likes this.
  17. JP
    JP 7480 74111110101115
    2,567
    NYC and Brookfield, CT
    My favorite are my most accurate, and all sport boron pipe.
    That's an awfully broad statement.
  18. Mister Pig
    10,646
    Olympia Washington
    Is there not? If not then why did some Signet cartridges have set screws to bolt the stylus assembly in?
    Now i am not a moving magnet cartridge guy, but didnt some hobbyists super glue stylus assemblies in place to minimize resonanc characteristics?
    Regards
    Mister Pig
    bobins08 likes this.
  19. JP
    2,567
    I'm sure some have movement, but others don't. I don't see friction-fit as reason for immediate condemnation.
    Same for hobbyists.
  20. OldADC
    OldADC Member
    97
    Nashua, NH
    Well there is absolutely no doubt that with replaceable styli cartridge designs that the fit of the stylus housing to the body must be very tight and stable.
    And I want to thank everyone for the inputs here. Very interesting reading. As I am designing this, I am pondering how to do a couple of things, with a clear eye toward the "design details" are the key dictum stated above.
    1) In the bad old days, the only elastomer with sufficient damping was butyl. I think I've discussed this before. But there are new choices in this realm that really change the balance between damping and stiffness available from the material
    2) A design were the cantilever/diamond assembly is removeable/interchangeable as has been common in the past with MM and MI designs. If different styli and diamond combinations were offered, then users could select the characteristics that appealed to them the most.
    3) I believe this could also be done with a MC design. Its a bit trickier but I can see it and have laid out the design. Just how careful can you guys be when replacing an assembly?
    4) Should I now engage the stone/wood/plastic body material debate? Just curious what others think. For me, a good design of a cartridge asks only that the body be effectively rigid and still. No relative motion. When folks debate the acoustic velocity in these materials, I think, while the heck should it matter? There should be no vibrational energy transmitting through the body so the acoustic velocity should have nada to do with it. If you hear a difference between body materials, its a sign the fundamental design is flawed!!
    Keep those insights coming! One day I'll get up the nerve to ask what you guys think of cartridge pricing.....(holds breath, covers ears, ducks quickly!!)
