Hi, got my hands on a pair of 6 Kappas. I am new to the world of hifi and plan to use it with my Dual 1218.
I need to replace the midrange drivers because the silicone is cracking and falling off.
What do I look for and how do I know it's compatible?
Thanks.
I believe those have been suggested in the past, and have been found wanting. If you do the search I suggested earlier, you should one or more threads discussing it.How about these ones?
Yeah I found a lot of posts about the polydome replacements. I just don't know if it's worth spending 100/150aud on replacement when I got both speakers for 280.I believe those have been suggested in the past, and have been found wanting. If you do the search I suggested earlier, you should one or more threads discussing it.
I checked the spec sheets on Infinity Classics, and the Polydome on the Kappa 6.1 is crossed over at only 100hz lower than on the RS4B, which uses the smaller Polydome. It's quite possible that the crossover frequency on the RS4B was chosen for reasons other than the dome's lower limit. However, I don't know if the impedance is the same for both, which would require crossover work on the Kappas (and these crossovers are not the easiest to work on - they're dual printed circuit boards, stacked). FWIW, the RS4b is rated at 4-8 ohms, while the Kappa 6.1 is 6 ohms.Nope. I don't believe they extend as low as they need to go, as the original 3" Kappa Polydome. At least, not without crossover modifications. Plus, those domes were used in the previous RS series, which consisted of the RS3A & B, RS4A & B, RS5 and RS5B, and RS6A & B. Good speakers too, and their domes don't fall apart.
