Hanleyster
ambitious but rubbish
Lets say you have your run of the mill cerwin vega 12" 3-way speaker.
What happens if you make it air tight and eliminate the port?
Science. Villchur and Kloss got it right. Porting had to wait for Thiel-Small to get it right with science.So no benefits unless you want to cut bass. Got it.
p.s. Why do sealed speakers like the AR-3a have such good bass when its sooo hard to push the woofer in? Is that why they take a lot of power? It just needs a lot of power to physically move the woofer inwards? Seems like they wouldnt have the same sort of SLAP as a ported speaker's woofer that was much more free to be tossed around by the watts.
Think of them as a ported enclosure with very rigid enclosure re-enforcement.There are a few reasons to go sealed over ported.
One is some drivers are better suited in a ported box versus sealed (and vice versa). I don't remember the specifics but the thiele small parameters will tell you which one it is better for (and some drivers can work well in both).
The other reason is bass extension. Sealed boxes have a smoother rolloff and extend deeper. They roll off at 12dB per octave.
Bass reflex (vented) rolls off at 24dB per octave.
And of course, the way the bass sounds is different with sealed versus ported.
Finally, efficiency. Bass reflex is more efficient because it has more output, whereas sealed is less so. If you want a very efficient speaker, most likely you are going to be building a bass reflex for the bass loading. The AR 3a is an excellent example of this. The bass is deep and extended, but as you know it is not a very efficient speaker. The driver was designed specifically for acoustic suspension, and I suspect the designers wanted the deeper, extended bass that a sealed enclosure allows so that they could get deeper bass out of a small (ish) enclosure.
There is, also, a third enclosure not discussed, which are transmission lines. However, they are a different animal. Similar to bass reflex in many aspects but different in others.
The port also allows the woofer to move efficiently increasing the output of the speaker. Close the port and you restrict the movement of the woofer increasing the impedance to the amplifier further reducing the output.
Reminds me of some one note wonder bass boom wedge speakers I had in the truck...They were designed with a huge peak in the bass for some reason.
It has been suggested by others, as well as the technicians who created them, to stuff a sock into the port of the speaker in my avatar(marantz imperial6.) I do on occasion to tighten up the bass but it does cut out some dynamics in the music. I know that's not sealing it though.
.. you'll end up with a sealed box with a slope closer to 6 db/octave...
The woofer design for a sealed enclosure tend to have a much looser surround and spider on older speakers like the AR. The air pressure it self helps stabilize the woofer where as a woofer for a ported enclosure tended to have a more rigid surround and stiffer spider. Today some woofers can be used for either but tend to work best with one or the other.So no benefits unless you want to cut bass. Got it.
