ron-c
Addicted Member
Using MC452 as an example of a Quad Balanced McIntosh amplifier, from the Owner's Manual:
'The MC452 is fully balanced from inputs and outputs. It consists of two matched power amplifiers operating in push-pull with their outputs combined in a McIntosh Autoformer. The Quad Balanced configuration cancels virtually all distortion'
Each channel of the MC452 has two independent 225 watt power amplifiers. These amplifiers and all input circuitry mirror each other and they are fed a balanced input signal with one amp inverted from the other.
This design will not allow induced noises and distortions in the output as these would be out of phase with the actual signal which a true balanced design cancels.
In the output Autoformer the two amplifiers are combined and outputted as a negative and positive signal. The terminal posts are 2 Ohm +, 2 Ohm-, 4 Ohm+, 4 Ohm-, 8 Ohm+, 8 Ohm-. The negative connection floats above any chassis ground as it is as 'hot' as the positive output terminal.
using this type of amplifier with and connection that shares ground between channels or grounds to chassis is a short circuit. These would not be the amps to use on SDA Polk speakers as an example.
The disadvantage of the Quad Balanced design is that the parts count is doubled in many parts of the amp, the autoformer and output connections.
Conventional 'balanced' amplifiers typically share chassis ground which means they are actually bridged. The McIntosh Quad Balanced will only work with the unique Autoformer.
A Quad Balanced amp will have a higher signal to noise ratio than other designs by 6 to 16 dB which is a lot. Quad Balanced was introduced on the MC1000 and has been used on many of the best models such as MC352, MC402, MC501, MC601, MC1201, MC1.2K, MC2KW and MC2301. The high signal to noise ratio of the Quad Balanced amps will exceed that of almost preamps so your sources will be reproduced
