david hafler invented the circuit and it works VERY well thank you. mine is always on to retrieve the ambience trapped in stereo recordings. it is the circuit that dolby pro logic is derived from.
i never use the derived center channel, phantom is just fine. live recordings become more like live as the audience is allowed into the back of the room. tomita records do nicely as isao recorded with surround in mind.
i don't have a 2 which would be nice with those banana jacks back there. even the original square quadaptor works wonderfully.
One of the best systems I ever owned was a pair of Stereo 70's run in mono ( chassis grounded to each other),PAS-3x ,, QD-1 ,A-35 on the front and A-25 on the rear. Especially on Angel Melodia's - this sounded way more natural than any of the overproduced/wackily engineered "true" four channel we sold at the time. I never remember it sounding worse on anything ( 'cept maybe mono to stereo "created" stereo LP's - and they sound a bit weird on anything) and the occasional simply miked stereo recording was simply stunning.
I never saw this QD-2 box - interesting ? Anybody know about when Dynaco was selling this product.?
to address musichal's question-an amplifier must be able to function in common ground. i believe that eliminates monoblocks or amplifiers of dual mono configuration.
Does anyone know if the Lepai 2020+ amp can safely be connected to derive the L-R signal? This sort of combines two current threads, but I have wondered previously whether the cheap little Lepai could be used this way, so this seems a good time and thread to inquire.
The connection for deriving L-R is connect from pos of L amp output to pos of L speaker, connecting pos R amp output to pos R speaker, then connecting the negative of the two speakers together. No connection is made to the negative outputs of the amp. This is what the QD-2 does internally to derive the ambience (L - R) rear signal. Some amps (I think some that do not share a common ground at outputs) cannot be connected this way without damage, how about the t-amps? Could be a fun use for them, if okay.
