Fisher didn't use P.E. TT's to my knowledge. Up to '65 they used Elac Miracord 10F's and DUAL 1009's.
After '65 It could have been a 1019, a BSR, or a 10F Depending on Model. The above is more than likely a DUAL.
It's not a '68 or '69 model. The Receiver is a 300Watt peak power according to the '69 brochure. Fisher took their stand alone Receivers and modified them slightly to fit and plug in, to the other components, namely the phono. My '69 Royal Electra is actually a 175-T without a case or heatsink. fishe built a perforated cage around the amp, instead of the heatsink that was on the 175-T. Hell of a AM section on it. FM on mine is PITA to figure out tho. Still trying to figure out whats wrong. Got it narrowed down to the FM Front end.
The Guts are worthy of Rehab. the GAUDY(for FISHER THIS IS GAUDY!) cabinet has to go. This would be a good bedroom, or basement easy listening set, with a set of FISHER XP-60's.
Larry
