What is your preferred way of connecting your digital files to your hi-fi system?
Discussion in 'Digital Sources' started by Sixtoys, Jun 14, 2018.
  1. Sixtoys
    Sixtoys New Member
    27
  2. Condorsat
    Condorsat Audio Enthusiast
    4,667
    Ohio
    Sober works for me.
  3. Unkle kaos
    Unkle kaos New Member
    8
    My Blu Ray player has a USB drive. I fill-up a thumb drive with tunes and play through that. I think it sounds a little better than straight from my PC.
    Bill Ferris and Sixtoys like this.
  4. chicks
    chicks Lunatic Member
    18,349
    The Big Valley, CA
    Wirelessly.
    ldatlof likes this.
  5. 4-2-7
    29,799
    San Francisco Peninsula
    As far as my computer files, music players, Youtube vids and all sound coming from my computer I go WiFi. I use a Audioengine D2, 24 bit WiFi DAC. It can be used just for it's WiFi if you have a better stand alone DAC or use the DAC it has. It's small and can you can move the transmitter to other things you might want to send to your system, CDP or a TV. You can also add up to 3 receivers and run different rooms from the same transmitter and source.
    Sixtoys likes this.
  6. Yamaki
    4,295
    Hillsboro, Oregon
    Network Attached Storage ===Cat V===>Music Server/PC===USB===>USB Reclocker===USB A to B===>DAC===Balanced XLR===>pre-amp
    Sixtoys and Alobar like this.
  7. judsonw
    judsonw Well-Known Member
    820
    Bellingham, WA, USA
    In the living room I have a HTPC laptop connected to a Marantz receiver by HDMI.
    In my bedroom: USB on Raspberry Pi with HifiBerry Digi+ ==> Coaxial ==> DAC ==> Tape Control Center ==> whichever output I want (Headphone Amp or Integrated Amp, but maybe soon a Yamaha receiver as well).
    Sixtoys likes this.
  8. KrisM
    KrisM Lunatic Member
    10,502
    The one that gets the most use is a hard drive(with mostly FLAC files) plugged into a computer, and accessed wirelessly on an Apple device with either the FileBrowser app, or the MusicStreamer app.
    At some point I plan on getting around to trying out the Pi solution.
    Sixtoys likes this.
  9. E-Stat
    7,027
    Ethernet
    awillia6 likes this.
  10. loopstick
    loopstick AK Subscriber Subscriber
    5,414
    PC Headphone Jack -> RCA Adapter -> Audio Cable -> Receiver AUX IN
    Sixtoys likes this.
  11. Silentnet
    948
    Charleston, SC
    PC connected via USB to Emotiva PT-100, or PS4 via HDMI to TV, then optical to PT-100.
    Sixtoys likes this.
  12. Bradbrews
    Bradbrews Member
    98
    Near Ann Arbor MI
    In my pole barn I have an old Windows XP PC hooked to a Behringer UCA222 that feeds the tape in of an old receiver. The UCA222 is USB to RCA.
    Previously I used whatever the best junk sound card I could find was and plugged it in via a 3.5 mm audio out to RCA jack.
    The UCA222 is only $30 and made a HUGE difference in sound quality, even on the junk system in the shop; Sherwood receiver feeding old Kenwood 3 ways.
    Everything in the System expect the UCA222 was literally picked up off of the curb. The receiver needed deoxit, but worked. The speakers have some swollen particle board bases on the cabinets, and some of the domes are pushed in, but they work also and I never feel bad about covering everyting in saw dust, over-spray, or rocking them when its -5F.
    Sixtoys likes this.
  13. mprince
    mprince AK Subscriber Subscriber
    1,683
    Mooresville, NC
    I run Logitech Media Server (LMS) on a desktop computer (which also houses all of my digital music), and use Chromecast Audio units (one plugged directly into amp in the garage, and one running through a cheap Fiio DAC in my main system) to stream via WiFi. There is an add-in for LMS that lets the CCA's function as Squeezebox players. Works perfectly for my needs, which is playing my own music as well as internet radio.
    ldatlof and Sixtoys like this.
  14. Alobar
    5,752
    SE Alaska
    Audio files (lossless) are stored on a 2TB NAS drive. JRiver on my PC provides the GUI and controls music, playlists etc which is being fed from the NAS direct to a Raspberry PI3b which is also running JRiver. All connections through Ethernet. The Raspberry then feeds the stream to a Schiit Multibit DAC via its USB interface. Total cost for the RPI and JRiver is under $100.
    After many fits and starts with other systems running from my noisy windows machine this has worked out stellar. Getting JRiver on the Raspberry was simple plug and play as it comes loaded and configured on a micro SD which also has the Linux OS. JRiver maintains the system through manual updates and the little RPi stays up 24/7 and uses something like 4 watts. It is completely reliable, always ready to play and dirt farmer friendly (well almost).
    gguillot, nedseg, ldatlof and 2 others like this.
  15. chodad
    chodad Well-Known Member
    721
    Northern NY
    USB to TeraDak dac to preamp​
    Sixtoys likes this.
  16. Captain581
    Captain581 Active Member
    158
    Dundas, Ontario, Canada
    I have a Xonar Essence STX sound card in my Windows 7 PC.
    I use high quality audio cable directly from the Xonar's rear RCA jacks straight to my Marantz AUX inputs. Tape 1 or Tape 2 inputs would be fine as well, but I prefer not to use the tape monitor push buttons to avoid any connectivity issues.
    The Xonar Essence STX DAC truly gives superb sound, and the Marantz 2270 finishes the job with aplomb. Beautiful sound that usually keeps me in my listening chair a lot longer than I'd planned.
    I use 320 kbps or FLAC only, with a separate hard drive in the computer dedicated to music only.
  17. Sixtoys
    Sixtoys New Member
    27
  18. Sixtoys
    Sixtoys New Member
    27
    How the two units connect between each other/stream files if not through the local wifi?
  19. E-Stat
    7,027
    CAT6
    mgosdin and Alobar like this.
  20. invaderzim
    invaderzim AK Subscriber Subscriber
    705
    California
    Squeezebox touch through NAD D1050 DAC, touch and Topping D30 DAC in another room and touch through cheap Ebay DAC board in the garage
    ldatlof likes this.
