Hi
My amp is going to be about 70Wrms per channel, 2 channels amp. I need to find a power transformer. My +B=400V. From loadline calculation, peak current is 600mA per channel that is 1.2A peak for both. This will give RMS current of 1.2 X 0.707 = 850mA just for the power tubes at maximum power output on both side.
I don't need 5V as I don't use tube rectifier. The 6.3V has to be able to provide 8A. It wound be nice to have like a 30V or so tap to get the -ve bias voltage for grid 1.
I know I need secondary voltage to be 400V X 0.707 = 283V or 285V with rectifiers. My questions are:
1) do I get 285-0-285 CT or just 285 non center tap and use bridge rectifier. Seems like 285-0-285 has the advantage of ripple at 120Hz rather than 60Hz, that will ease the requirement of the filter caps.
2) We all know we don't run maximum power all the time. I don't think we need 850mA max current. The question is what is the standard calculation given the maximum is 0.85A? 500mA? or 400mA?
I want to get some suggestion of what brand I can look at. This is not OPT, so I go as cheap as possible. Chinese transformer is OK with me. I am born cheap. I don't want to spend a penny more than I have to on the power transformer.
Thanks
Thanks
