What to use to glue tuner window into aluminum faceplate?
Discussion in 'DIY' started by Scott75s1974, Nov 10, 2018.
  1. Scott75s1974
    Scott75s1974 Active Member
    217
    Ohio
    I have a Scott R75s (~1974) and the acrylic window is glued into the faceplate, which is a heavy aluminum extrusion.
    The original glue looks like yellowish hotmelt. I'm sure it's something else, but it held the bead shape like hotmelt glue and peels off the acrylic easily. It definitely did not do anything solvent like to the acrylic window.
    I tried using hotmelt, but the faceplate is so massive, it cools too quickly to stick for long. I have some Barges contact cement I could try. Any other suggestions?
  2. gadget73
    37,359
    Southern NJ
    clear silicone maybe.
  3. Watthour
    Very likely it is a contact adhesive, like Armstrong 520.
    Scott75s1974 likes this.
  4. KingBubba
    10,108
    Brooksville, Fl.
    I used Alenne's Tacky Glue on my Pioneer. It is water soluble so getting it off would be no trouble.
  5. tyeeslayer
    tyeeslayer Super Member
    3,143
    Abbotsford, British Columbia
    3M double sided tape.
    Scott75s1974 and ETLS like this.
  6. KingBubba
    10,108
    Brooksville, Fl.
    The issue to be aware of is the possibility that you ever have to remove a broken glass in the future. Gorilla glue is definitely out.
  7. MCS Guy
    MCS Guy The MCS hoarder Subscriber
    592
    FL
    Pretty much what I have used. Usually can find tacky glue in crafting stores.
  8. gadget73
    37,359
    Southern NJ
    very true. Silicone will let go without much fuss. The water based glues should too, provided you get them wet first.
  9. fernarias
    fernarias Super Member
    1,107
    Merced, CA
    That's what I've been using since that's what I'm finding in some of these. Anything that does not contain petroleum, that would out gas and ruin the painted silk screen, and easily removable should be fine.
    Scott75s1974 and Lavane like this.
  10. triode17
    triode17 Super Member
    1,375
    I had to glue a glass meter window on my Hewlett-Packard meter. I used epoxy spread carefully around the edges. Its on permanently.
  11. audio80
    audio80 New Member
    3
    be careful if you use silicone,some strong silicone vapour will discolor the clear plastic,almost like the vapours are melting it.I tried that on an old car amp that had analog guageswith clear plastic covers. the silicon fogged up the plastic real good.I would personally use a little bit of hot melt.as its not permanent and be easily removed with alochol.
  12. DEAFASABAT
    DEAFASABAT Active Member
    248
    Santa Barbara County, Ca
    Use electronics grade silicone RTV. The "silicone vapor" is outgassing acetic acid, potentially corrosive to many materials. Electronics grade is more benign.
    merlynski likes this.
  13. Scott75s1974
    217
    Ohio
    Thanks for all the replies. On closer examination, I decided the old glue really was hot melt. So, instead of trying to lay a bed of glue on the faceplate and pushing the acrylic into it before it hardened... I had the brilliant insight of reproducing what they did. Mount the face plate and run a bead along the top and bottom like they did.
    Unsurprisingly, this worked. Sorry for the noise.
  14. EastPoint
    4,736
    Milwaukee, WI
    I just use standard Elmer’s white glue for this. Never had any issues.
