What's a good pair of bookshelf speakers for an Eico HF-81?
Discussion in 'Tube Audio' started by Eafnb, Jul 1, 2018.
  1. Eafnb
    Eafnb New Member
    19
    I'm planning to buy the Kef Q100 to pair with an Eico HF-81, would the Eico be enough to power the Q100s with 14wpc, or should I go for a different pair of speakers?
  2. radioactive
    radioactive tube gear fanatic Subscriber
    8,896
    winnipeg , manitoba
    Klipsch heresy are nice bookshelf speakers and very efficient.
    GChief and drtool like this.
  3. Eafnb
    Eafnb New Member
    19
    Sorry, I forgot to specify that I am on a budget for $300 or less. I don't want to break the bank as much as I really want to :(
  4. drtool
    drtool It might get loud In Houston Subscriber
    2,215
    Houston Texas
    I have seen used pairs go for around that (heresy).
  5. Harvestor
    Harvestor Super Member
    drtool likes this.
  6. Harvestor
    I love Ohm Acoustics speakers...
    Here's mine
    drtool likes this.
  7. Eafnb
    Eafnb New Member
    19
    You know, oddly enough there is an upcoming garage sale selling a pair of OHM speakers in my area I'm not sure if it's the Model L though. Sadly I'm looking for something smaller like the Q100s or the Elac B6 (which is something I also should've specified :confused:).
  8. primosounds
    3,064
    Terra, 21st century CE
    When i was using my 81, i had a pair of JBL L112 which a little big but can be condsidered "bookshelf" speakers. The L100 are the same drivers in a slightly different arrangement that were very popular as studio monitors way back in the day.
  9. savatage1973
    7,087
    NW Pennsylvania snow belt
    The KEF's are not very efficient ~86 dB, so they will not play very loudly on a small amplifier like your Eico. I would look for something closer to or greater than 90 dB efficiency.
    KentTeffeteller likes this.
  10. KentTeffeteller
    KentTeffeteller Gimpus Stereophilus! Subscriber
    26,470
    Athens, TN
    I'd look in to getting something in the mid 90 dB/1 watt/1 Meter. Dynaco A 25 would be about the easiest option for a bookshelf or AR 4x. Both of those are 90ish dB/1 watt/1 meter efficient.
  11. soundmotor
    soundmotor super modified
    How big is your room or listening area?
    RWood likes this.
  12. Hi-FiGuy
    Hi-FiGuy AK Subscriber Subscriber
    583
    Southern California
    Check out B&W DM601 or the DM602 speakers. I prefer the Series 2 version, better tweeter. If you get the first series, I would recommend replacing the electrolytic capacitors in the crossover with film caps, Much better sound.
    2526 likes this.
  13. arts
    arts Super Member
    3,893
    Qc, Canada
    I get the impression that you guys have some really huge bookshelves......
    drtool likes this.
  14. Dave451
    Dave451 AK Subscriber Subscriber
    1,319
    Philly area
    I have a pair of AR-4x and love them. Unfortunately, they are relatively insensitive. I don't think they're above 87dB, maybe 85. Nevertheless, they drive well and sound great with my Scott amps (20-25WRMS per channel) and Fisher receivers and amps (25-35WRMS per channel). Your Eico is a great amp, but a little light on power, so, as KentTeffeteller says, you'd want something probably in the 90 dB range for your Eico.
    Dave
    PS Kent, I haven't found many (any?) acoustic suspension speakers that are much better than mid-80 dB sensitivity, although admittedly it's hard to find the actual specs for the AR-4x.
  15. squirrelnest
    squirrelnest Addicted Member
    7,467
    Alexandria, VA
  16. nikon f
    nikon f Member
    78
    ADS L470 or any 500 series speakers.
  17. Tom Bombadil
    Tom Bombadil AK Member Subscriber
    1,776
    Madison, Wisconsin
    The Dynaco A25 was measured way back in the 70s as having an efficiency of 82-83dB/1 watt. There was one published report of them being measured at 90dB but it was with a 10 watt signal and at 6'. So increase to 93dB at 3', reduce to 83dB with 1 watt. Both reports were consistent.
  18. soundmotor
    Without more info from the OP this is shooting in the dark.
  19. Eafnb
    Eafnb New Member
    19
    The thing is, is that my room is small so would efficient speakers matter?
    My room is about 137.7778 sq ft (10ft 8in x 12ft 11in)
    My apologies for not giving more info, this is my first post :(
  20. silversport
    silversport Super Member
    2,540
    ChicagoLand-USA
    both a bit large as bookshelf speakers but I have enjoyed both Klipsch kg2s and RB-5/RB-5 IIs with my EICO HF-81...good luck with your choice.
    Bill
