Correct - just plain old JFET'sI guess we're not talking about "MOS"-FETS here.
Except you need decoupling with valves/tubes.....Back then someone said that 'FET's were the semiconductor equivalent of a Valve' (Tube) - being a 'voltage controlled' device rather than 'current controlled' (as are bipolar transistors) - and suddenly everyone had to have them in their designs.
So for slimplicty sake...Two of the things I go to when trying to explain why tube gear sounds different than solid state:
1. Tubes, driven to their optimal performance range with high voltage, don't produce perfectly linear amplification like solid state does.
2. When they distort, tubes produce even-order distortion and solid state produces odd-order distortion.
So, I understand I can have the above two statements wrong. If so, please say so.
My questions for this thread are:
1. Is FET operating characteristic curves mostly linear like solid state? Or are they curved?
2. When pushed beyond their operating curves, do FETs produce even-order or odd-order distortion?
For input switching and for switchmode class 'D' operation, yes.Maybe I got it wrong also, but I thought that FETs were basically used as a switches. They are "ON" if no controlling voltage is applied to the gate, and they are turned "OFF" as voltage to the gate is increased.
