Hi Patrice,
I acquired this MR78 knowing that the signal strength meter was not working. Exactly why it stopped working is a mystery. However, it appears that the meter itself is actually open. I came to this conclusion because the meter has a 4.7k resistor across its terminals which is exactly what I measure with my DMM.
I have a new meter from McIntosh parts. As a simple test, I used clip leads to connect the new meter to the old one. The new meter seems to work as expected while the old meter is still dead.
At this point I'm fairly certain the old meter is open. I suppose it could have some debris in the movement, but either way, I need to remove it from the chassis.
-Matt
