Zarathustra
The more expensive Infinity's all have provisions to bi-amplify them with or without a dedicated control unit.
As far as I know the QLS, Q2, Kappa 8 & 9 don't have such a CU but the rest starting in time with the QRS have one. The most expensive ones with apart cabinets for the low-end like the RS-1 and IRS (has a 2 kW amp iside its basscolumn) must be biamped.
My question is this:
- Apart from the benefit of using two stereo amps, four mono amps or a combination of those and having generally speaking more power to "play' with, what's the most beneficiary thing to use the bi-amp provision for the Infinity's that have that provision?
Remarks: With an active crossover you can have a dedicated amplifier for only amplifying a portion of the frequency-spectrum dedicated by the crossoverpoints. The amplifier is less stressed by that feature.
With an Infinity (maybe apart from the IRS) both amps amplify the whole frequency-spectrum and the CU or crossover inside the speaker "blocks" the portion that's not needed to drive the units the speaker binding posts is connected with.
I operate a QLS with a Conrad Johnson EVO2000 mosfet on the midbass/mid/high section and different amps (Krell KSA-100, Perreaux PMF3150 and Denon POA-3000) on the bass section.
All the amps above are capable to drive the QLS fullrange to a SPL that's adequate to deny any conversation within 15 feet of the speakers.
- Thoughts about horizontal or vertical bi-amping?
I'm really curious about your thoughts regarding this matter.
