altecchris
New Member
Hi does anyone know or can point me in the right direction to how the three speaker wire taps are to be connected on this speaker, I have done some googling but do to their apparent rarity I am having trouble finding this type of info.
Starting from the left the first tap is labeled on the inside as #1 the second tap is labeled as #2 and the third tap has no number but is marked with green tape on both speakers.
From what info I have been able to put together if I understand correctly, the third wire tap marked as green is the negative? And the ones marked 1 and 2 are the positives that you use one of them if your amp has a dedicated 16 ohm tap or the other if you amp or receiver only has an 8 ohm tap? Something to do with the damping was what I took from it.
I have three tube amp setups I'm gonna be trying out on them. A custom homebuilt single ended tube amp that has 4-8-16 ohm taps, a pair of audionote el34 tube mono blocks that have only 4 and 8 ohm taps, and lastly a pair of thor tpa 30 tube mono blocks that only have a single set of taps.
I am gonna be trying out all the amps eventually with the speakers to determine which I like the best sound wise, so far they have only been run with the audionote monos, but would like to know the proper wiring order to use the 16 ohm tap on my homebuilt, plus a it's actually the one I personally favor sound wise and suspect will matchup the best with the the legatos.
Any help would be appreciated.
Thanks
Chris
Thanks
Chris
