old_tv_nut said:Simple test: Switch from stereo to mono - if you hear the noise level decrease, then a better antenna probably will help.
What do you mean by noise level? Added sound asside from the music? Any other way to test this?old_tv_nut said:Simple test: Switch from stereo to mono - if you hear the noise level decrease, then a better antenna probably will help.
c3conv said:What do you mean by noise level? Added sound asside from the music? Any other way to test this?
I have this favorite station, the problem is that it still can not trigger the FM STEREO indicator light at signal level 4. unlike the other station it lights up at lelvel 3. That's why I am asking if it will improve the sound or not. If it will I will get hold of an aerial.
Paul C said:When I do listen to a weak, distant station that is noisy, of course, switching to mono will many times clean up the sound. My preamp and a receiver both have a simulated stereo feature I can switch on. This does a pretty good job.
But I would much rather listen to clean mono than noisy stereo.
There is this GREAT jazz station I can sometimes pick up at night, but its about 200 miles away.
How about underwater?kc8mob said:Now I know someone is going to tell me it's impossible to transmit stereo amplitude modulation.
kc8mob said:Ok Ok, Im going to post plans to a dual stacked 5/8 wave antenna.
Also, I would try staying away from receive pre-amps. They bring in everything, even Santa's sleigh bells.
If you use a stacked 5/8 wave and you can achieve some hight you should do very well for your self. I live about 17 miles north of the river here and I can hit a repeater in Indianapolis, and that's running a Icom 2100H on a stacked 5/8 wave. (55 watts out)
This is a ground plane antenna btw.
Also for you guys who get incorrigible interference on a certain part of the band, I have the solution for you chaps too.
Use a 1/4 wave trap. Now it's really easy to make, and will kill any and all intermod you may be getting. So if it's the not the frequency you want, you won't get it.
1/4 wave trap: Determine the frequency you wish to center this trap on. Get an extra piece of coax that is a 1/4 wavelength of this determined frq. Then multiply the velocity factor of the coax by the quarter wavelength and thats your piece of cable. ( It's going to be a decimal point, like .95 for 95%) Now you can install this like a "T" it doesn't matter where in the cable run, just install it with a 'T' connector. Use 'F' connectors if you can or even better PL-259 or SO-239 jobbies. Now here is the weird part. At the end of the 1/4 wavelength of cable, connect the shield to the center conductor, yes short them together. Use a switch though, this is a narrow filter and you would want to remove it out of the line and maybe switch in another one on a different part of the band.
SHORT THE END OF THE 1/4 WAVELENGTH CABLE.
Now if you study antennas and transmitters, receivers you would find that at the determined frequency your receiver or transmitter for that matter will see an open circuit because it is at 1/4 wavelength. This means that the frequencies you want will not be shunted to ground, but the crap you do not want like harmonics and intermod from god knows what will be shorted out and become nonexistent before your receivers front end tries to demodulate the garbage.
WHAT.....? Yes that is true.
Ok now I just have to scan some plans I have of my antenna I made, We can adjust it for FM broadcast band without any problem.
understood with the computation but please elaborate on the T connection and so on. thanks.kc8mob said:Now you can install this like a "T" it doesn't matter where in the cable run, just install it with a 'T' connector. Use 'F' connectors if you can or even better PL-259 or SO-239 jobbies. Now here is the weird part. At the end of the 1/4 wavelength of cable, connect the shield to the center conductor, yes short them together. Use a switch though, this is a narrow filter and you would want to remove it out of the line and maybe switch in another one on a different part of the band.
increased signal strength will improve sound quality up to the point of full quieting, after that it can actually cause problems with overload of the front end letting stations on other frequencies in the passband mix with the desired station causing intermodulation distortionc3conv said:I have been getting a good reception from the stations I am listening into, will adding an aireal improve the sound or just increase the signal level? thanks
am stereo is possible and its called cquam, but it still doesnt have the bandwidth available at higher frequencies used by fm broadcast. my sencore am fm signal generator has am stereo although ive never needed it, and i also have an am stereo radio in my old truck i drive to work.kc8mob said:Are you talking about AM or FM for this range. I would assume FM because there aren't too many receivers out there that can receive stereo AM, also there are not too many, probably just a handful of stations that transmit AM stereo.
