Sam08861
Super Member
Hi All,
I posted on the solid state forum for some specific help, but no responses so far. (Here... has photos of the unit and link to service manual.... http://audiokarma.org/forums/index....-capacitor-list-for-the-technics-9070.841921/ )
I'm recapping a preamp (Technics Su-9070) and have the service manual, which lists all the electrolytics and also has notation for those that are non polar. For the electrolytics, I'm planning on using Elna Simlic IIs and Low ESRs for the power supply caps. For the non polars, I'll use nichicon muse.
Where there's a call for low leakage caps, I'll use nichicon ukl, but not sure which ones need this.
What I can't figure out is which ones should be low leakage? Any suggestions for which sections might need the UKLs or notations I should look for?
The amp, power, mc prepre, phono, etc. sections are all clearly separated and labeled on the board and the signal path from the inputs to the outputs is followable, so ever general guidance would be helpful. (i.e. the power supply caps should be all ESR as an example, but looking to understand which ones are low leakage specifically before ordering the caps)
There's also paper caps at the power switch and switched outlet on the back. Do I need to replace these? If so, what would you reccomend? PIO?
Below is a snap of the cap list. Ones in shaded grey are non polars.
There's one more line on the next column, but it's just a repeat of the last line for the paper capacitor.
Here's how the layout is from some marketing materials. Same diagram is in the service manual
Any help greatly appreciated!
Thanks,
Sam
- List is broken up by section. For instance the first grouping (C101,102 through C115,116) is the 100s or MC pre-pre amp,
- 200s is EQ amp and EQ subsonic
- 300s is DC flat amp
- 400s is power supply and muting section
- 600s is 2 caps next to the inputs
- 700s are the 2 pios I mentioned earlier.
Thanks,
Sam
