so it doesnt really matter if some have more output power than the others (range is from 40 to 60)? All sounds practically the same, right?All the models you listed are essentially the same, circuit wise. All good amplifiers.
That's right. If you used them all side by side, you wouldn't be able to tell them apart. Output power in such insignificant numbers is negligible.so it doesnt really matter if some have more output power than the others (range is from 40 to 60)? All sounds practically the same, right?
thanks for letting me know! Something else, a bit off-topic, someone locally is trying to sell me Marantz 1090. Can does this amp compare to L-2xx series?L30 is older and its performance is significantly worse than the 2xx series and similar 80s Lux men.
215 has plastic knobs but with a nice finish. Only the l400 and 500 series has metal knobs.
Luxman quality is probably more variable than any other brand. I've had to-die-for Luxman gear, and some that basically sucks. My current preamp is an all-tube Luxman and I'll never part with it. I've had some of their SS gear and calling it "mediocre" is being gentle. On the other hand, their "Lab Reference" SS pre + power were magnificent.
"Zoom" thanks for helping me with decision! Do you know if I can leave the amp powered on all the time, or it's necessary to turn it off?Damn that looks nice.
