Part 432 - POWER OUTPUT CLAIMS FOR AMPLIFIERS UTILIZED IN HOME
ENTERTAINMENT PRODUCTS
1. The authority citation for part 432 continues to read as follows:
Authority: 38 Stat. 717, as amended; (15 U.S.C. 41-58).
2. Section 432.2 is revised to read as follows:
§ 432.2 Required disclosures.
(a) Whenever any direct or indirect representation is made of the power output,
power band or power frequency response, or distortion characteristics of sound power
amplification equipment, the following disclosure shall be made clearly, conspicuously,
and more prominently than any other representations or disclosures permitted under this
part: the manufacturer’s rated minimum sine wave continuous average power output, in
watts, per channel (if the equipment is designed to amplify two or more channels
simultaneously) at an impedance of 8 ohms, or, if the amplifier is not designed for an 8-
ohm impedance, at the impedance for which the amplifier is primarily designed, measured
with all associated channels fully driven to rated per channel power. Provided, however,33
when measuring maximum per channel output of self-powered combination speaker
systems that employ two or more amplifiers dedicated to different portions of the audio
frequency spectrum, such as those incorporated into combination subwoofer-satellite
speaker systems, only those channels dedicated to the same audio frequency spectrum
should be considered associated channels that need be fully driven simultaneously to rated
per channel power.
(b) In addition, whenever any direct or indirect representation is made of the
power output, power band or power frequency response, or distortion characteristics of
sound power amplification equipment in any product brochure or manufacturer
specification sheet, the following disclosures also shall be made clearly, conspicuously, and
more prominently than any other representations or disclosures permitted under this part:
(1) The manufacturer’s rated power band or power frequency response, in Hertz
(Hz), for the rated power output required to be disclosed in paragraph (a) of this section;
and
(2) The manufacturer’s rated percentage of maximum total harmonic distortion at
any power level from 250 mW to the rated power output, and its corresponding rated
power band or power frequency response.
3. Section 432.3(c) is revised to read as follows:
§ 432.3 Standard test conditions.
(c) The amplifier shall be preconditioned by simultaneously operating all channels
at one-eighth of rated power output for one hour using a sinusoidal wave at a frequency of34
1,000 Hz; provided, however, that for amplifiers utilized as a component in a self-powered
subwoofer system, the sinusoidal wave used as a preconditioning signal may be any
frequency within the amplifier’s intended operating bandwidth that will allow the amplifier
to be driven to one-eighth of rated power for one hour;
By direction of the Commission.
Donald S. Clark
Secretary
