z-adamson
Addicted Member
Diodes, resistors, capacitors, transistors..............all have long leads to trim down after installation.
Variable resistors......ie. Bourns 3296 series multiturn variable resistors......have very short leads making them difficult to use sometimes without soldering extensions onto the leads.
I can't think of any advantage to this.
Why don't they make them long with the idea that the leads will be cut down after being soldered into place on the PCB as is the case with just about all other components?
