Why would someone do this? Crossover modification...
Discussion in 'Infinity Loudspeakers' started by Ross6860, Oct 15, 2018.
  1. Ross6860
    Ross6860 AK Subscriber Subscriber
    1,773
    Ohio
    Infinity RS-IIIa
    Several owners ago, they built these crossovers.
    Any idea what they were trying to achieve? I would think Infinity put at least some cursory investigation into the crossover when they built the speaker.
    Also looks like they removed the zeners protecting the tweeter.
    It will cost me a bit, but I'm thinking of rebuilding them with the factory specs.
    I could pass them on since I have a pair of RS-II that could also use some refreshing, and there's only so much room for floor-standers.
  2. Brunt
    Brunt Member
    54
    San Diego
    Having heard both a fully restored pair of IIIbs and a pair of original condition RSIIs (read: in need of significant restoration), I vote the RSIIs all day. The IIIbs are nice speakers, but the dipole and odd bass crossover of the RSII put it on another level if you have the space.
  3. jazzmans
    jazzmans Super Member
    2,399
    devils playground, NV
    as an owner of rs 4b and rs IIb, what brunt said. they are completely different sounding speakers. the rs4b aren't bad at all, but not nearly on the same level as the II a/b.
    I'd sell them with full disclosure of the crossover modifications, or try to find a rs 3/4 crossover from a pair that have been parted out?
    but no question, I'd keep the rs II
  4. audiotemp
    audiotemp Well-Known Member
    590
    That factory drawing won't give you a working crossover. The tweeter circuit, as drawn, is wrong.
  5. Tedrick
    Tedrick Infinity-phile Subscriber
    7,060
    Gainesville, FL
    I have to concur with @jazzmans and @Brunt. Since I got IIb's, my IIIb's have been completely sidelined.
  6. Ross6860
    1,773
    Ohio
    Would you care to elaborate? Should the cap be between the fuse and inductor?
    Just to clarify, my speakers are RS-II, not RS-IIa/b. Still very happy with them and they aren't going anywhere. If a pair of IIa/b, 2.5 or 4.5 come along, well maybe that would change.
    So far no one has conjectured what the mods were supposed to "improve".
  7. elnaldo
    elnaldo Addicted Member
    7,440
    Buenos Aires GMT-3
    I'd compare the crossovers with picts from the web. It's possible the drawing is OK and the Spec sheet is wrong. Anyway they are not too different (just another capacitor in the woofer, a bit different crossover slope, and the 1ohm resistor on the tweeter, filtering a bit the freqs going to the inductor, so smoothing the slope just a bit)
    The specs sheet says "2-way speaker", "tweeterS", and "woofer" (singular), so seems plenty of errors (and the inductor-capacitor mistake too).
    I'd search images of the crossover board, and check if that 1 ohm resistor exists in the original, if it has 2 capacitors in the woofer section, and if it has the zeners, or just the fuse. (inductors are the same , 5 on each crossover)
    Here is a pict of what seems to be stock crossovers: https://us.v-cdn.net/5021930/uploads/attachments/8/2/6/2/4/60359.jpg (no affiliation)
  8. audiotemp
    590
    Hey, I thought I had responded to this...sorry.
    Yes, as drawn the inductor just provides a load but does no filtering. It's possible there are other errors as well. I'd look for confirmation elsewhere before assuming the factory drawing will give you something better than what you have.
    BrianLW likes this.
