Widest soundstage thrown by a sansui ?
Discussion in 'Exclusively Sansui' started by quadklipsh, Dec 4, 2018.
  1. quadklipsh
    quadklipsh Super Member
    1,377
    Lahore, Pakistan
    Hi all.
    I would like to know which sansui model excells in soundstage width and depth.
    I'm truly impressed by the 707x that i have recently purchased. It far exceeds any amp IV owned
  2. quadklipsh
    1,377
    Lahore, Pakistan
    FOR ME
    AUD707X
  3. peerson
    peerson Well-Known Member
    991
    Kansas City area
    Your listening space and room acoustics and speaker placement has alot to do with your Soundstage. Maybe even more that any particular model of amp.
    BLAH BLAH likes this.
  4. quadklipsh
    1,377
    Lahore, Pakistan
    Peerson.
    I think we all agree to that .
    But when you play two amps, one after the other ,in the same place with the same speakers and wires and look for differences then the only variable we have is "the amp" in question.
    Id like to take it from there .
    Now which one do you think sounded wide open.
  5. Hyperion
    49,767
    Hertfordshire, UK
    Not sure about 'wide open' but most detailed = AU-alpha907Limited ;)
  6. Grenadeslio
    Grenadeslio Super Member
    3,658
    Didn't you know, all amps sound identical right down to their ability to throw a soundstage, no matter if it came from a transistor radio or a Krell, as long as neither is taxed it makes no difference lol.
  7. quadklipsh
    1,377
    Lahore, Pakistan
    I think i would differ there and i can be wrong.
    No wonder a transistor sells for 5 bucks and a krell sells for several grands . Im sure the magic lies somewhere in that metallic box where they handle those taxes ;)
  8. quadklipsh
    1,377
    Lahore, Pakistan
    Please enter with straight answers. Like hyperion mentioned the alphas.
    :beerchug:
  9. peerson
    991
    Kansas City area
    Understood. I was unaware that you were comparing in an equal environment. Sorry
    t
  10. stopkidding
    stopkidding Well-Known Member
    547
  11. Grenadeslio
    3,658
  12. slimecity
    slimecity Super Member
    3,237
    New Zealand
    What does your tech tell you is the best one for soundstage?
  13. quadklipsh
    1,377
    Lahore, Pakistan
    Marantz pm8 .hed say .:mad:
  14. bluesky
    bluesky Addicted Member
    7,667
    I just play the music. :music:
  15. Gazdatronik
    Gazdatronik Super Member
    1,500
    Chattanooga TN via Chicago
    Something is probably wrong with one of them.
  16. quadklipsh
    1,377
    Lahore, Pakistan
    Like what
  17. spark1
    spark1 Super Member
    1,913
    The Great Midwest
    AU-919
  18. Gazdatronik
    1,500
    A phase issue internally, perhaps. Only a scope could tell you for sure what it was doing, and from there it would have to be diagnosed or perhaps adjusted.
  19. quadklipsh
    1,377
    Lahore, Pakistan
    Im afraid im not following your point....
  20. Gazdatronik
    1,500
    An amp should play the source material back as recorded. It should not change anything about it.
    If one amp is different from another in power or voicing, such as equalization, that is more normal.
    If an amp widens, or narrows the soundstage for that matter, there could be something out of spec about it.
    For instance, my preamp has a width/blend knob, which can sum or difference the channels. If its out of adjustment, the channels can crosstalk to one another.
    Alternatively, if a transistor or out of spec capacitor or some other thing is changing the sound either in the preamp section or the amp section, it can make for some strange artifacts.
    I once had a digital synthesizer that seemed to sound like it was three dimensional compared to others like it. It had other issues, so I reseated the chips and re-capped it as well. That "effect" went away when I powered it back up.
    I also had a Scott receiver that the mono button was acting up on. It would occaisionally reduce the stereo effect unless you messed with it for a minute.
