Worst Headphones Ever??
Discussion in 'Headphones' started by Chrisxo55441, Mar 28, 2018.
  1. Chrisxo55441
    Chrisxo55441 AK Subscriber Subscriber
    2,574
    Twin Cities Minnesota
    I have a partial tear in my quadriceps above the knee and i went to have an MRI done, the tech/nurse said it would take 20 min and asked if i wanted to listen to some music and i said yes and he put some headphones on. the sound was absolutely the worst all garbled and the only thing that was kind of clear were drums. it was so bad i commented to the tech when i was done. he said that unfortunately metal or wires cant be anywhere in the room. these things give wireless headphones a whole new meaning. i looked at them and they were connected with a clear vinyl tube. not sure how they worked, sound is pump through in the air ???
    just thought i would share and see if anyone knows how these work.
    reydelaplaya likes this.
  2. JoeESP9
    17,122
    Philadelphia PA
    I believe they're called Air Tube headphones. There is a speaker at the other end of the chain that sends sound down an air tube.
    You can't have any ferrous metals near an MRI machine. They are giant electromagnets. Their magnetic field is strong enough to generate voltage pulses in a coil of copper wire.
    boza, cratz2, whyaskit and 2 others like this.
  3. Alobar
    5,939
    SE Alaska
    So would these be a passive radiator??
  4. lini
    lini just me...
    6,045
    Munich, Bavaria
    Iirc, the Lockheed TriStar I flew with, when I visited the US for the first time in 1993, still had "pneumatic audio"/"air tube headphones". Nothing to write home about in terms of sound quality - but, damn, that TriStar was really comfy, even in the economy class and even for pretty tall folks like me... Nice passenger plane. (Note to myself: Ask uncle Manfred about cockpit comfort level of the F-104.)
    Greetings from Munich!
    Manfred / lini
    Retrovert and Chrisxo55441 like this.
  5. Nightcleaner
    Nightcleaner Well-Known Member
    792
    Bournemouth UK
    Igrado portables Great name: great sound even : but gee don't they hurt your ears : one album had to take them off. Plus the wire your going to break it no matter how careful you are at some stage.
  6. lini
    lini just me...
    6,045
    Munich, Bavaria
    Alobar: Maybe I'm mistaken, but iirc the ones in the TriStar basically just were open tubes without any additional membranes - so these rather wouldn't qualify as passive radiators.
    Manfred / lini
    Alobar likes this.
  7. skraggs
    skraggs Well-Known Member
    503
    Basel, Switzerland
    Yeah I remember those from the MRIs I've had. Still better than any Bose headphones though.
  8. Pio1980
    Pio1980 AK Member Subscriber
    28,644
    Eastern Bamastan
    Lafayette had an all acoustic stereophonic integrated cartridge/ tonarm/ sound tubes /stethoscope attachment for a turntable that was an interesting thing to play with back in the 1960s.
  9. Tom Brennan
    Tom Brennan AK Member
    16,064
    San Antonio
    Members only, ladies invited.
  10. reydelaplaya
    reydelaplaya AK Subscriber Subscriber
    2,713
    Aguadilla, PR
    Beyond the aforementioned TriStar, wasn’t this style the norm on most commercial airplanes up til maybe the end of the 80s.
    I’m almost positive I remember the ‘headphones’ they had for the in flight movies were like modified stethoscopes that plugged into a pair of ‘airholes’ in the armrest. Adjustable volume by restricting airflow with that little wheel.
    Pneumatic headphones, they’re apparently called.
    Third post down explains them in detail.
    https://aviation.stackexchange.com/...ic-headphones-on-airliners-in-the-70s-and-80s
    Pio1980 likes this.
  11. Bill Ashton
    Bill Ashton AK Subscriber Subscriber
    928
    Central Massachusetts
    Ah, "Uncle Manfred," I'll bite...Lockheed F-104...wicked fast Mach-2 jet fighter...that glided like a rock? :D
  12. c.coyle
    c.coyle Fighting the Dunning-Kruger effect. Subscriber
    3,481
    40.339044,-76.423500
    I've had three total quad tendon tears. Right off the kneecap. Nasty injury. The shitty MRI cans are there to distract you from your misery. Stay strong
    Pio1980 likes this.
  13. Chrisxo55441
    2,574
    yes very painful injury at least i dont need surgery on mine but it sounds like you must of 3 times OUCH!!. i was just going to start therapy on a couple of bad disc in my back when this happened and lying down keeping my leg elevated aggravates the back so i just cant win here.
  14. petemcfc
    petemcfc Well-Known Member
    757
    Gt. Manchester UK
    By your description they don't.:D
    Hope things work out,just got over a hamstring injury due to getting carried away on a rowing machine.
  15. lini
    lini just me...
    6,045
    Munich, Bavaria
    B_A: My uncle Manfred's first career was jet pilot and later on trainer/teacher for the Bundeswehr Luftwaffe, both over here and in the US - and yes, the F-104 (which over here is known as the "Starfighter") was one of the types he used to fly.
    Well, and in case your "glided like a rock" was supposed to allude to the row of accidents with the F-104: As far as I'm aware, that foremost was a "homemade" problem. Iirc, one part of the problem was that especially variant G had different/more avionics installed and became rather "nose-heavy" due to that. But I guess the main part of the problem rather was that our Bundeswehr Luftwaffe had inherited this odd tendency to abuse fighter models for mixed fighter-bomber duty. This is kinda traditional, one might say, 'cause that problem already started with the first German jet fighter, the Me262, which on Hitler's command also already was pressed into the figther-bomber role, due to which it lost its main advantage over the Allied fighter planes, i.e. its superior speed. Good for us, though, 'cause this and quite a few other of Hitler's stupid ideas/interventions actually saved us from an even longer, even more destructive war - or, even worse, from the Nazis actually winning. Anyway, back to the fighter-bomber problem: Later on they even thought about converting the Alpha Jet to that role. The Alpha Jet! Imagine that: A neat little trainer, that's not exactly fast to begin with, in fighter-bomber duty... Gives "ludicrous speed" a new sense. *lol*
    Manfred / lini
  16. HarmanKardon
    HarmanKardon Tubes still smell funny Subscriber
    61,960
    Schwarzwald, Deutschland
    Just for the record...
    The F-104 was also known over here as "Witwenmacher" ("widowmaker").
    Back to the topic...
    Pio1980 likes this.
  17. Grbluen
    Grbluen AK Subscriber Subscriber
    2,415
    HarmanKardon likes this.
  18. twiiii
    twiiii Addicted Member
    6,931
    west Texas
    The headphones my dad used when he flew B-17's, 24's, in ferry service and C-47's and C-54's in the transport command. Those had to be the worst thing ever. I guess I should have kept them, but the last time he used them was 48 years ago.
  19. Pio1980
    28,644
    Eastern Bamastan
    The Telephonics phones I've tried haven't been bad, audiologists use them.
