X-101-C Phono Section Is Squealing Badly
Discussion in 'Fisher' started by 3l3ctron, Jul 13, 2018.
  1. 3l3ctron
    3l3ctron Active Member
    239
    West Seattle, Washington.
    It worked perfectly fine last night for the hour that I was using it.
    Today it is passing no audio from the turntable from either phono 1 or 2. It is only making that awful noise.
    The first thing I did was swapped out the tubes with a good set. It made no difference.
    The other channels still work normally.
    I’m looking under the hood, and there are no obvious signs of trouble. Everything appears normal.
  2. 3l3ctron
    239
    I cleaned the switches, and it is back to normal. I’m glad it was something easy. Whew!!!
    RUmad and I LIKE MUSIC like this.
  3. 3l3ctron
    239
  4. audmod01
    audmod01 Super Member
    1,388
    Tioga, TX
    Glad you found it! I was going to suggest just what you did. I have an X-101-C too and as part of the restoration I had to clean the function switches plus the slide switches. It had sat for a long time in a very humid environment.
    Joe
  5. 3l3ctron
    239
    Thanks. Me too! I had cleaned all of the switches and pots about 6 months ago at the time of the rebuild, and thought that it was going to be a much bigger problem.
