I was blowing the dust out of a x100b. In the photo below (not the actual amp in question) you will notice in the bottom left corner a metal cap/cover with a blob of solder on it. It covers the power switch/volume control.
On mine I noticed that the blob of solder doesn't hold the cover in place firm, you can wiggle it a bit.
I was concerned of this movement since the cap is metal and its covering a joint that is line voltage.... don't want to see sparks and a tripped circuit breaker or course.
Is that cover supposed to be firm, unable to be wiggled side to side?
