The Xiaomi Bluetooth Audio Receiver sports a minimalistic and compact design. It is fabricated from advanced polycarbonate plastic, the simple white color exemplifies the classic Mi-looks, which works well as a fashion accessory. The metal elastic belt clip secures the device and makes it ultraportable. It comes with One key operation, that is, all function on board is controlled by a single key which turns on the earphones, connects to Bluetooth, plays, and pulses music, also answer calls, instantly transforming your earphones from wired to wireless.
Product Features:
● One button operation, all functions onboard are controlled with a single key.
● Supports connecting with two Bluetooth devices simultaneously.
● Bluetooth V4.2 wireless connection, 10m transmission distance, great efficiency of receiving, stable and fast signal transmission speed.
● Processed precise tuning and professional amplifier chip, deliver high SNR low distortion signal, return natural and original sound.
● Built-in 97mAh Li-ion battery, charging 2 hours lasts 4 - 5 hours playing time.
● Plug and play, supports using while charging, not afraid of no power.
● Connect the device to car's head unit, wirelessly play music on car's audio system.
● Metal clip-on design, footloose for doing sports.
● Standard 3.5mm audio port, compatible with a variety of earphones or headphones.
No need for a wired smartphone connection while exercising, you can go for a run with your favorite beats! Enjoy your personal time on a lazy afternoon without worrying about smartphone radiations or external disturbances. No need to worry about making a call while the mobile phone is on charge. All this is due to the Xiaomi Bluetooth audio receiver, which priced at $19.99 on GearVita, will give you a wonderful experience: https://gearvita.com/xiaomi-bluetooth-audio-receiver.html
Hot sale products:
xiaomi mi max 3 4g smartphone in stock
xiaomi lyej05lm in stock
Product Features:
Hot sale products:
