The Xiaomi Mijia 1S walkie talkie is packed with some powerful features – a huge 10km range, 8 days of standby time and up to 17 hours of talk time, GPS positioning and even an FM radio function. It has a detachable antenna for easy storage and has a micro-USB port for charging that can also be powered with a power bank. It supports the Very High Frequency (VHF) range spanning from 136MHz to 174MHz, also comes with support for the Ultra High Frequency (UHF), i.e. the frequency range between 403MHz and 470MHz. On top of that, the device comes with support for FM Radio, allowing you to tune in to your favorite radio stations, also capable of location sharing.
Product Features:
● 41% thinner than last generation, 43% lighter, built-in back clip, one hand handling.
● Not only support 3.5mm earphone port, but support Bluetooth headset with dual mode Bluetooth chip.
● Micro USB charging port, no need to worry about loss of charger, convenient and practical.
● Quick to form a team, once one starts a team, the others can click to join the team without putting complicated frequency.
● Location share function, in the range of calls, it can check the location of teammates by the screen or App even there is no Internet.
● 2190mAh big capacity battery, micro-USB charging design.
● Long time to use, 8 days stand-by time,17 hours for normal use.
● Auto detection function during charging, prevent the risk of overcharge, over discharge, over voltage and other issues.
● FM radio function, it can search channel in 87 - 108MHz, providing entertainment apart from communication, but the talking between walkie talkie have priority when listening to radio.
● Digital filtration, good talking effect even in various complicated environment.
● In order to achieve clearer and louder call sound, the speaker has a speaker volume that is 65% larger than the effective radiation area of the previous generation. The maximum volume is increased by 162%, and in a noisy environment, good call performance can still be maintained.
● Sending voice without pressing talking button when your volume is reached to a certain level,free your hands.
● Suitable for two-way communication from different locations.
● A maximum power of 3W and a call distance of 1-5 kilometers in order to meet the call needs in a variety of scenarious.
● Comes with UHF frequency range of 403-470MHz, and VHF frequency range of 136-174MHz, give it the ability to be used in a densely populated area as well as in the wild where there is little or no obstruction to the radio waves.
● Comes in black and white colors with along with handy display and some buttons on the surface for controlling the device.
The 1S walkie talkie which available on GearVita is a practical gadget, can be used almost anywhere, including metropolitan areas with a high degree of radio interference: https://gearvita.com/xiaomi-mijia-1s-smart-walkie-talkie.html
You may like:
cheap airdots headset
buy honor watch magic
Product Features:
You may like:
