guy232
Member
Service manual .pdf hosted:
https://docdro.id/EbfVYvc
I've been doing some work (details listed below) on my R-70 and learning quite a bit but it still sounds rather poor as it initially did, also the left channel is weaker. I've tested the device unloaded and all of the PS voltages are in spec, cleaned pots (concentric pot that has vol/bal), cleaned mechanical switches, a few electrical switches used to control the LCD may have not been cleaned well but I read they dont cause audio issues?
I don't exactly know what a properly working system should sound like. I believe something may be wrong though because the R-70 sounds noticeably worse to even my untrained ear compared to a similar era/spec amp (80s Fisher CA-39, "BPC"). There is no comparison between the units, the CA-39 sounds much better using the same speakers/wires/room/input etc.
I've done the following:
- Replaced all main board caps with Nichicon HE/PW, all matched to uf/v specs except for filter caps (oem:8500uF/55v, replaced w/ 10000uf/55v)
Note: Out of the old caps, four 100uF 6.3v caps were out of spec, 3 of them were in "Power Amp" and 1 was in "Relay"
- Power on, no load tested DC offset & PS voltages to spec
- Power on, load, tapped around on board to discover tapping on relay caused channels to drop out. Desoldered, cleaned contacts deoxit d5+printer paper, resoldered. No longer responds to being tapped.
- Reflowed the speaker terminals, rca inputs, and a couple questionable old joints
Most tasks that I havent done yet require a scope I believe. I've been waiting for a decent deal to pop up. Meanwhile at my current position; is there more I can check on the device or is further diagnosis best done via scope?
I seen that fusible resistors were recommended in a sticky here, planning to desolder and test them shortly -- I'm not sure if those could cause these issues though?
Any advice/links are welcome, will update if I discover anything new meanwhile.
Cheers fellas,
Guy232
Cheers fellas,
Guy232
