stozek2000
New Member
Hi, I've got a problem with Yamaha CR 1020. The receiver was damaged, there was a lack of -25V voltage and I manager to fix it. It worked fine for the next couple of days and the next issue appeared. Just after I turn it on everything is fine, but after a few minutes the signal is very distorted (the same issue in both channels). You can find the oscilloscope record on the video on YouTube. I also did the preamplifier measurements and marked on the picture the moments where the signal starts to be distorted. I just wanted to know if that would be the fault of the adapter (event hough both +-25V voltages are fine). Did anyone of you have a similar issue? Any help appreciated Thanks
