JesusJones
Well-Known Member
I picked up one of these for pretty cheap. After a I cleaned out the pots with some contact cleaner it was working like a charm. Very nice, clear sound. But not very bass heavy, which I like. But still very good.
It has this "class A" mode as well. Which I had high hopes for
But pushing the button seems to make no difference in sound. I'm not sure if it's not working or if there just isn't a BIG audible difference. Any one know or have experience with such a function?
And the main reason that I am posting is that I have 2 concerns with this amp that I'd like to have sorted out before I put it into daily use....I noticed that when I started playing music at a moderate level that the amp started to get VERY hot. Almost too hot to touch the heat sinks. This was only at moderate volume.....maybe 9-10 o'clock on the volume control. None of my other amps get anywhere near that hot. (the others MIGHT get warm)
Any one think that might be normal? Putting it into class A seemed to make it much hotter, much faster(I didn't experiment very much but that's what it seemed like)
And my second concern would be the DC offset. I noticed upon start up it was around 300mv then made its way down to 0 and 3mv. Which is good, but should I be worried about that initial surge?
I'm hoping the heat issue(if it's even an issue at all) is related to bias. I would of checked it out by now but finding a service manual is proving to be nearly impossible. (hint hint) :thmbsp:
Cheers,
Rudy
P.S. There are some nice pictures here if you wanna see what this thing is all about.
http://www.hifi-wiki.de/index.php/Yamaha_A-700
Cheers,
Rudy
