I bought a Yamaha A-960 with a couple issues , First is the Main Direct switch. It looks like someone took it apart and soldered the pins together inside and removed the copper "sliders" that make or break the direct connection so it was set to only the tone control setting. So I bought a 6PDT C&K switch. This one here http://www.mouser.com/ProductDetail/CK-Components/F6UEE/?qs=sGAEpiMZZMvxtGF7dlGNpkvuTQHbvtlSnge8p3X2G5o=
http://www.mouser.com/ds/2/60/Fpush_1nov12-221205.pdf
One difference was the old switch had a center pin at the end of the pins and it was connected to one side of the outer pins on the PCB. The other outer pin on the old switch was not connected on the PCB ( no solder pad from factory)
Now when I selected the Main Direct switch to by pass the tone control the main power light dimmed and the protection relay clicked on I shut it down right away and now removed the new switch.
So my question is, is the new switch wrong type? I can not tell how toehold switch was exactly inside due to it being bastardized . One thing I did was test how the Disc button opperated as in theory it works the same. and the new switch contacts made the same continuity as the Disc switch( 4 pole vs 6 pole) .
the schematics are not clear as they do not really go into detail on the switch or its internal operation. and the board layout drawing is not the best So that is why I added the pic of the board.
Yammy experts what is my next move?
Athanasios
Athanasios
