Dr. Ear
Super Member
My two otherwise perfectly working Yamaha B-6 power amps have both 110 Volts on their housing. There is a small electrical sensation only when I touch the amp and another earthed device simultaneously. Current to ground is negligibly. This voltage gives me some hum in the preamp's phono input and killed the muting transistors of my C-80 when I connected it to the B-6 with power on (the B-6 was off, of course). The voltage is also there when the B-6 are not switched on (!) and independently from the position of the mains plug. I have installed a shielded mains cable and exchanged the spark suppressor caps which are directly soldered to the power switch in one of them, no change. Now I have earthed the amplifiers which solves the problem but I would like to know the reason for this voltage. Could it be a defective power switch?
